![]() | Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK? |
GazP Member Since: 06 Apr 2013 Location: Stevenage Posts: 29 ![]() ![]() ![]() |
I have a knock which fits this description but two different specialists have told me that is is just the anti roll bar bushes... i say just despite hearing they both need 2 to 4 hours to fit new ones |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 ![]() ![]() ![]() |
Mine has CLONKED since 3000 miles. Cannot be bothered to even ask LR to look at it. Now done 50k and still CLONKS ![]() Are you telling me the ALL NEW RRS 2014 @ �87.000 (with toys I would like) will still CLONK ? ![]() Corris grey and ivory leather + most of the toys. Limited edition RRS model number 0001 ![]() Gone TDV8 RR Sport. Never to be forgotten. Wife has an i8 BMW |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
Just had my rumbling front suspension sorted - new ARB bushes and modified mounting bracket. Silence has been restored. FF 4.4 V8 Soooo looking forward to this bad boy
YES GOOD. |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
(repost) one mechanic that inspected my car and recommended changing front ARB bushes, also said they would remove two components that contribute to the noise and actually serve no purpose. in fact Land Rover recommend these are removed. does anyone know what he was referring to. he did tell me but it escapes me now (there were so many problems we discussed with the car, ive forgotten what this was) 07 TDV8 + BAS map |
Ben1975 Member Since: 21 Sep 2012 Location: Aylesbury Posts: 5 ![]() ![]() ![]() |
So last year I had a TDV8 (09) and then a supercharger (59)... both knocked and rattled so I gave up and flogged them both.... Have just bought a 12 plate supercharger and it's brilliant. Totally silent, drives in a straight line. Land Rover made a few changes over the years, the most significant being the modified ARB compressor from a different supplier. It can be retro-fitted, but it's the most expensive option.
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
Guys, I may have posted this in the maintenance section also but can I pick your brains?
LEESY Member Since: 25 Mar 2010 Location: Manchester Posts: 14 ![]() ![]() ![]() |
" new ARB bushes and modified mounting bracket."
I guess it would be a Google job for LR parts suppliers.
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 ![]() ![]() ![]() |
So before I go and buy one of these - is it hit and miss that you get a crappy one? Is there something you can ask the owner for before making the deal - or is it that they just go and you are stuck with it. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Test drive it over a broken surface. You'll know if the bushes need doing - it's a very obvious noise.
Cool - testing on the weekend with one. Looks lovely but I hear dealers do them up to look better to bling you to sale! |
mcdziubek Member Since: 14 Aug 2014 Location: Cippenham Posts: 3 ![]() ![]() ![]() |
Is this knocking is so bad that the car can't be used or it is just annoying clonk every time you turm steering wheel? Does the knock stops when at motorway speed? |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
The items to remove are the front body to chassis dampers mounted at the back of the front wheel arches and hidden by the wheel arch liners. They do not actually contribute to the noise but they do act as one of two noise transmission paths to the cabin. (The other path is via the No. 2 body mounts) PS Only just realised that the original post is over a year old - still the info might still help someone. |
