Home > Technical > [FAQ] WARNING - DOES YOUR FRONT SUSPENSION KNOCK?
Page 30 of 32 <123 ... 29 303132>
AudiRoyal
Czech Republic 2010 Range Rover Sport Supercharged Santorini Black
2014 RRS DRS
2014 RRS has dynamic response? If yes, same problem like with previous? Is there an option not to take it?
Post #378885 Thu Mar 28 2013 10:44am
GazP
United Kingdom 2006 Range Rover Sport Supercharged Adriatic Blue
I have a knock which fits this description but two different specialists have told me that is is just the anti roll bar bushes... i say just despite hearing they both need 2 to 4 hours to fit new ones Shocked ...perhaps I'm a bit new to the RRS to be able to tell the difference myself
Post #380170 Thu Apr 11 2013 8:21pm
Baron
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Re: 2014 RRS DRS
Mine has CLONKED since 3000 miles. Cannot be bothered to even ask LR to look at it. Now done 50k and still CLONKS Rolling with laughter
Are you telling me the ALL NEW RRS 2014 @ £87.000 (with toys I would like) will still CLONK ?
Censored  SDV8 vogue SE.
Corris grey and ivory leather + most of the toys.
Limited edition RRS model number 0001 Smile
Gone TDV8 RR Sport. Never to be forgotten.
Wife has an i8 BMW
Post #388277 Tue Jul 09 2013 10:32pm
Bradders
Just had my rumbling front suspension sorted - new ARB bushes and modified mounting bracket. Silence has been restored. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #388285 Wed Jul 10 2013 7:29am
Baron
YES GOOD. Whistle
But how long will it last Censored  SDV8 vogue SE.
Wife has an i8 BMW
Post #388354 Wed Jul 10 2013 9:46pm
jack.bauer
(repost) one mechanic that inspected my car and recommended changing front ARB bushes, also said they would remove two components that contribute to the noise and actually serve no purpose. in fact Land Rover recommend these are removed. does anyone know what he was referring to. he did tell me but it escapes me now (there were so many problems we discussed with the car, ive forgotten what this was) 07 TDV8 + BAS map
Post #391017 Tue Aug 06 2013 12:50am
Ben1975
United Kingdom 2010 Range Rover Sport Supercharged Siberian Silver
So last year I had a TDV8 (09) and then a supercharger (59)... both knocked and rattled so I gave up and flogged them both.... Have just bought a 12 plate supercharger and it's brilliant. Totally silent, drives in a straight line. Land Rover made a few changes over the years, the most significant being the modified ARB compressor from a different supplier. It can be retro-fitted, but it's the most expensive option.
Lost count of how many pot-holes and drains I've driven over - totally silent. There is light at the end of the tunnel. Ben
Post #393601 Mon Sep 02 2013 8:10pm
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Guys, I may have posted this in the maintenance section also but can I pick your brains?
I purchased my RRS HSE which is a 2007 from a main dealer in Bristol.
I've been reading this most excellent forum and came across the clunking suspension debate. I have downloaded the TSB which someone posted a link to.
When I took my RRS back to them initially to correct an air suspension fault after 4 weeks, I mentioned to the salesman that it felt a bit "clunky" underneath which I didn't expect from a RRS.
He said...."oh that's normal" and quickly changed the subject.
I did leave however with a full 12 months warranty. The issues on this TSB to resolve the clunking front suspension, should this be covered in my warranty?........is it a kind of recall that is free?
I want to know if I can go back before the warranty runs out?
They should at least know if the car has received the work on this TSB shouldn't they.
Cheers,
Gaz.
Post #399045 Sat Oct 19 2013 4:10pm
LEESY
" new ARB bushes and modified mounting bracket."
hi, any ideas where my local garage can get these parts? quite pronto lol ?!
Matt LEESY
Post #400237 Mon Oct 28 2013 4:54pm
Gaz
I guess it would be a Google job for LR parts suppliers.
I did watch an old Wheeler Dealers where Edd replaced these on an old P38.
The original ones were rubber and for a little more, he replaced them with like a neoprene version which was much more durable.
Quite easy but I think you need a ramp really.
Gaz.
Post #400239 Mon Oct 28 2013 4:59pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
So before I go and buy one of these - is it hit and miss that you get a crappy one? Is there something you can ask the owner for before making the deal - or is it that they just go and you are stuck with it.
Post #412704 Wed Feb 05 2014 9:39pm
Test drive it over a broken surface. You'll know if the bushes need doing - it's a very obvious noise.
They do all seem to suffer eventually it's just a matter of when, not if. 2012 SDV6 - it's missing a couple of cylinders
Post #412733 Thu Feb 06 2014 12:56am
designboy
Cool - testing on the weekend with one. Looks lovely but I hear dealers do them up to look better to bling you to sale!
Post #412801 Thu Feb 06 2014 12:05pm
mcdziubek
Is this knocking is so bad that the car can't be used or it is just annoying clonk every time you turm steering wheel? Does the knock stops when at motorway speed?
Post #433296 Fri Aug 15 2014 3:49pm
Bob.
The items to remove are the front body to chassis dampers mounted at the back of the front wheel arches and hidden by the wheel arch liners. They do not actually contribute to the noise but they do act as one of two noise transmission paths to the cabin. (The other path is via the No. 2 body mounts)
PS Only just realised that the original post is over a year old - still the info might still help someone.
Post #433384 Sat Aug 16 2014 9:49pm
