Home > General > Possible Detachable Tow Bar Issue
Page 2 of 3 <123>
muddywheels
Milk Float Man
Simonsti - I can see in your case LR may advise you to use the fixed tow bar recommended "for commercial and constant use" with towing weekly. I am using a 3-4 year old tow bar from my previous sport and have always felt safe towing the caravan until now - I have used mine for around 5-6 trips per year towing the caravan and consider this to be "Leisure use" Confused
I have never heard/seen/read advice limiting detachable to 50/750kg until now - this would effectively limit them to garden trailer use Shocked Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #397646 Tue Oct 08 2013 12:21pm
Meccles
Australia 2013 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
Interesting that the tow hitch JLR supply in OZ is different again. It has the quick release section as a separate part, with a 50mm square section that a 50mm bar pins into -like a standard Haymen Reece set up. I haven't seen many comments on Aulro about these failing. Looks good on a Sport. There are aftermarket hitches also in use for really heavy duty use (mitch hitch etc) SWMBO owns this car I get to drive occasionally Smile
Post #397649 Tue Oct 08 2013 12:54pm
muddywheels
Milk Float Man
I have read somewhere that Oz has to be different because you have heavier off-road caravans/trailers - i think it was on a caravan forum Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #397651 Tue Oct 08 2013 1:02pm
SimonR
Hay - what do I know! I only have a 3.5 Ton Brian James Trailer that's used on & off road with the standard tow-bar.
Si
Post #397673 Tue Oct 08 2013 3:20pm
Meccles
When I am next back in Oz will send copy of JLR blurb/part numbers for this hitch. It is listed as D3/4 RRS part.
Have never fully understood why different balls/hitches are required for different regions when all are in theory rated at 3500kgs.Seems that some are "light duty" 3500 kg - but the JLR documents/manuals make no such distinction. We use a 50mm ball in Oz same as UK. The cut out in boot of RRS is for the UK ball. Confused SWMBO owns this car I get to drive occasionally Smile
Post #397741 Wed Oct 09 2013 4:51am
garrycol
Australia
Aussie cars also have a 350kg tow ball weight where I think the UK cars are 150kg. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #397754 Wed Oct 09 2013 8:51am
mse
The Auz and US towbars, with the square receivers are cool - but there are some reasons why we cant have them here.
I remember that from my old disco days, they also had the US square receiver hitch option. I have one on my current disco, off road it can take a square recover hitch, it has a drop plate for towing and is low profile so it doesnt get in the way off roading. Mike
2014 Facelift Discovery
Post #397759 Wed Oct 09 2013 9:47am
There'll be a homologation issue for why we can't have the Oz hitch here. Probably some small corner of the EU that doesn't like it so no one in the EU can have it. 2012 SDV6 - it's missing a couple of cylinders
Post #397762 Wed Oct 09 2013 9:54am
mse
Yes for towing that is one massive issue Mike
Post #397765 Wed Oct 09 2013 10:13am
hondagoneda
United Kingdom 2012 Range Rover Sport SDV6 HSE Zermatt Silver
I hope this one runs until at least LR has a (better) solution,
I tow too, my caravan is about 1650Kg. Fortunately my RRS tow stuff is new and the detachable hitch seems to have a very positive click in the lock position, the key comes out easily too. I have put a film bit of grease where the detachable bit pushes into the chassis, keeping the ball cover in place when it is stowed.
Without teaching granny to suck eggs an all that - I am hoping to find a place on the chassis to fasten the breakaway cable now, not for me is it going around the 50mm Ball any longer Rolling Eyes SDV6 HSE, Indus Silver/Ebony
Sometimes up front of a Bailey Pamplona Caravan
Post #397785 Wed Oct 09 2013 12:47pm
muddywheels
Milk Float Man
I hook my brake cable on one of the loops to the receiver in chassis - it would not fit MY10 loop so fed it through recovery ring near electrics on that one Thumbs Up Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #397789 Wed Oct 09 2013 1:04pm
What's wrong with using the recovery loop immediately above the tow ball housing? That's what I do with the cable for our horse trailer. 2012 SDV6 - it's missing a couple of cylinders
Post #397790 Wed Oct 09 2013 1:06pm
muddywheels
Milk Float Man
I was warned against this as it can foul when turning, etc - much safer below on proper loops - I always meant to change the clip but never got round to it Embarassed Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #397792 Wed Oct 09 2013 1:11pm
hondagoneda
Thanks Muddy, I wondered about the loops on the receiver and hope the cable will go on oner of those Thumbs Up SDV6 HSE, Indus Silver/Ebony
Post #397793 Wed Oct 09 2013 1:25pm
Never found the recovery loop to result in fouling whilst turning... 2012 SDV6 - it's missing a couple of cylinders
Post #397797 Wed Oct 09 2013 1:30pm
Page 2 of 3 <123>
