![]() | Home > General > Possible Detachable Tow Bar Issue |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
Just be aware that the chassis loops are not up to the job when towing a heavy trailer. There has been one reported incident here where a heavy caravan and D3 parted ways and the loops failed with the chain shackles pulling through the hoops.
I take it that your caravans do not have security chains. Here all trailers/caravans must have security chains that connect it to the tow vehicle and trailers/vans over 2 tonnes also have to have a breakaway system that activates the trailer brakes if the safety chains fail (after the tow hitch arrangement has failed) and the trailer actually parts company from the car. In the situation I mentioned above, the caravan hitch detached from the car and the weight of the caravan was taken by the safety chains which ripped out of the holes that are in the rear cross member for this purpose, the van then parted the D3 completely and the breakaway brakes activated stopping the van - however the shackle points on the D3 for the safety chains should not have failed. Irrespective of the fitting of brake-away brakes, in our system the van and car should always remain connected together, irrespective if the hitch fails. 07MY RRS TDV6 Arctic Frost Aspen Interior |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
We use the type shown to pull on caravan handbrake if it comes detached - it is designed to snap |
So if your hitch fails and you are doing 100kph, the van and the car parts company and even though the van brakes are applied it still is doing 100kph slowing down ad taking maybe 200m to stop - in the intervening time it has wiped out heaps of cars.
