Home > General > Prop shaft
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Prop shaft
Just changer my ARB bushes and had a look over the underside of my RRS as i was flat on my back and spotter that the prop shaft has a support were it joins its after the transfer box and befor the compressor
Big steel ring with a rubber centre ? Well half of the rubber is split
What's the proper name for it and it it easy to change please
Thanks
Neil
Post #389408 Sat Jul 20 2013 12:26pm
flack
Transmission
Support Insulator
Flack Thumbs Up
Post #389411 Sat Jul 20 2013 4:54pm
ShooterNeil
Is it easy to swap ?
Looks like unbolt prop from each end ?
Bearing (will it pull off ) will I need a press to get it back on ?
This I think is the part I need
http://www.paddockspares.com/toq000050-bearing.html
Post #389435 Sat Jul 20 2013 9:16pm
flack
Yes easy job prop off and then knock the old off ..
Flack Thumbs Up
Post #389438 Sat Jul 20 2013 10:06pm
simple1
If its the centre carrier bearing then it can be changed but it is a ball ache to do. Complete prop is £225 new from LR and will also replace the worn universal joints you will have Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #389451 Sun Jul 21 2013 7:09am
ShooterNeil
Thanks
Looks like I will be working my way from the front to the back replacing all things rubber mounted Neutral
Lower arms /steering arms /ball joints and droplinks all in the garage ready to be fitted
Must get a new 24 pack of WD40
Post #389456 Sun Jul 21 2013 8:24am
Tre4
2011 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
I need the propshaft looked at on a different car and was recommended Dave Mac Propshafts in Coventry by a reliable in trade source. Not actually used them yet, but will be popping over as soon as this set of shifts end.
http://www.davemacprops.com/dmphome.html MY11 RRS HSE
Buck Blue
Post #389469 Sun Jul 21 2013 10:14am
ShooterNeil
Can you drive the car with no prop ?
Post #389625 Mon Jul 22 2013 8:31pm
simple1
Er.... That will be a No! Milestone on the silly scale Rolling with laughter for the transfer box to work it needs resistance from both front and rear. If you removed prop, the box will go into effective neutral. Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #389630 Mon Jul 22 2013 8:58pm
ShooterNeil
Was just thinking if I needed to go and get fags / beer if it was not going well lol
Post #389631 Mon Jul 22 2013 9:04pm
ShooterNeil
Well my part come
So I got started and got the first 6 bolts out at the front in seconds easy
But only got one of the rear 4 bolts out as I did not have good Access or room on the floor so it's all bolted back up till the weekend
Q / is there a way to rotate the prop to make life easier and get better access to the bolts
Or can I just remove the front part of the prop if so how as had it all lose but not apart
Post #389733 Tue Jul 23 2013 8:17pm
