Home > General > Prop shaft |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Transmission
Sat Jul 20 2013 4:54pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Is it easy to swap ?
Sat Jul 20 2013 9:16pm |
Yes easy job prop off and then knock the old off ..
Sat Jul 20 2013 10:06pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
If its the centre carrier bearing then it can be changed but it is a ball ache to do. Complete prop is £225 new from LR and will also replace the worn universal joints you will have 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Jul 21 2013 7:09am |
Thanks
Sun Jul 21 2013 8:24am |
Tre4 Member Since: 14 Sep 2012 Location: S.Warwickshire Posts: 29 |
I need the propshaft looked at on a different car and was recommended Dave Mac Propshafts in Coventry by a reliable in trade source. Not actually used them yet, but will be popping over as soon as this set of shifts end.
Sun Jul 21 2013 10:14am |
Can you drive the car with no prop ? |
Mon Jul 22 2013 8:31pm |
Er.... That will be a No! on the silly scale for the transfer box to work it needs resistance from both front and rear. If you removed prop, the box will go into effective neutral. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Jul 22 2013 8:58pm |
Was just thinking if I needed to go and get fags / beer if it was not going well lol |
Mon Jul 22 2013 9:04pm |
Well my part come
Tue Jul 23 2013 8:17pm |
