![]() | Home > General > Prop shaft |
Transmission
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Is it easy to swap ?
Yes easy job prop off and then knock the old off ..
If its the centre carrier bearing then it can be changed but it is a ball ache to do. Complete prop is £225 new from LR and will also replace the worn universal joints you will have |
Thanks
Tre4 Member Since: 14 Sep 2012 Location: S.Warwickshire Posts: 29 ![]() ![]() |
I need the propshaft looked at on a different car and was recommended Dave Mac Propshafts in Coventry by a reliable in trade source. Not actually used them yet, but will be popping over as soon as this set of shifts end.
Can you drive the car with no prop ? |
Er.... That will be a No! |
Was just thinking if I needed to go and get fags / beer if it was not going well lol |
Well my part come
