![]() | Home > Technical > How to fit new wishbone (lower arm) and track rod end |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Why do you have to loosen/push back the drive shaft |
ShooterNeil
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
As Flack said |
I've got a press and still chose to change the whole thing. Depends on how much youre willing to spend on it really.
That's what I was thinking but cheaper is not always better so the new full arms will be going on
Rear bolt is stuck fast what's the best way to cut it off as after an hour of wd40 a hammer and lots of wiggling it just won't move |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4446 ![]() ![]() ![]() |
9 inch grinder. Cut the arm off so you can get the grinder back in to cut through the bush and bolt |
Thanks Disco_Mikey
Time to start all over again lol 8 years on and the 3 RRS 61 AB 5.0 supercharged rocket
