Home > Technical > How to fit new wishbone (lower arm) and track rod end
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Hi Guys,
Here's how I changed my front wishbones (lower arms) and track rod ends. Pics are also available in my gallery on the RRS site.
Tools:
Jack
Axle Stand
Locking wheel nut key
5mm allen key
10mm long socket or with extender
15mm spanner
18mm socket or spanner
21mm socket
21mm spanner
24mm spanner x2
32mm Socket
hammer
Torque Wrench
Wire Brush
Thin flat bladed screwdriver
Consumables
Copper Grease
WD40
Torque Settings:
Track rod end ball joint nut - 70nm
Track rod end locking nuts - 53nm
Shock absorber and spring assembly to lower arm bolt - 300nm
Lower arm ball joint retaining nut - 115nm
Lower arm bolts - 275nm
Hub Nut - 230nm
Wheel bolts - 140nm
Torque settings taken from this page:
http://www.rrsport.co.uk/gallery/albums/us...ension.jpg
Time: 2 - 3 hours per side
Prep:
Lower vehicle to access height
Lock vehicle in access height
Apply Electronic Park Brake (EPB)
Step 1
Using a thin, flat bladed screwdriver, carefully prise the centre cap out.
Step 2
Using the 32mm socket, loosen the hub nut but do not remove
Step 3
Loosen but do not remove the wheel nuts
Step 4
Lower vehicle to access height and lock. Apply EPB then steer the wheels full lock towards the side you will be working on.
Step 5
jack the vehicle up remembering to use axle stands to support the weight. Remove the wheel nuts and remove the wheel
Step 6
Locate the track rod end and spray the nuts with WD40. Use a wire brush to remove rust, especially on the nut located on the track rod itself.
Step 7
Using two 24mm spanners, undo the nut on the track rod.
Step 8
Using an 18mm spanner, undo and remove the nut on the hub carrier. If the thread spins whilst you are trying to undo the nut, you may need to use a 5mm allen key to counter turn.
Step 9
Undo the nut on the track rod and mark the point on the thread where the track rod end stops. This will ensure you put your replacement track rod end in the same position as the old one, so your tracking should be almost the same as before.
Step 10
Using a 15mm spanner, turn the track rod enough for it to loosen the thread within the track rod end.
Step 11
Use a splitter tool to separate the track rod end from the hub carrier.
do not break the tool Sad
Step 12
My replacement track rod end was slightly different to the one fitted to my RRS. Not sure if it's a discovery one or a newer item. I just have to take this into account when re-fitting onto the track rod.
Screw the new track rod end onto the track rod, upto the point you marked in step 9 (take into account any difference in length between old and new track rod ends)
Tighten the nut on the track rod.
Wishbone time....
Step 13
Leave the track rod separated from the hub carrier for the time being.
Remove the rear-most undertray by undoing the six 10mm bolts.
Step 14
Spray WD40 on all the nuts and bolts connected to the wishbone. There are 3 bolts/nuts connected to the wishbone, as well as a ball joint with a nut on the underside of the hub carrier.
Here's the end result of what you're working with...
Step 15
After the WD40 has had a chance to soak in, mark out the position of the eccentric cams at both the bolt end and the nut end. I did this by spraying primer around it. This will ensure that the tracking will be fairly similar once the new wishbone is in place.
Step 16
Loosen and remove the four 24mm nuts around the wishbone.
Front
Rear
Suspension Strut
Front of suspension strut (21mm)
Lower Ball Joint
Step 17
Remove the nut from the driveshaft (loosened in step 2) and push the driveshaft towards the engine so it pops out of the hub carrier. You may need to give it some gentle persuasion with a hammer and centre punch.
Step 18
Remove the suspension strut bolt.
Step 19
Remove the lower ball joint from the hub carrier. You may need to use the splitter again - mine just hammered out.
Step 20
You should be left with this.
If your bolts are siezed inside the bush like my rear one was then having the wishbone in this position will give you a good angle to work with.
The siezed rear bolt
I kept turning the bolt and fighting against the springiness of the bush, regularly spraying WD40. The bush eventually gave way and I was able to pull the bolt out without having to cut it.
The bolt had rusted and siezed to the sleeve of the bush:
Step 21
Pull all the bolts out and remove the wishbone.
Step 22
Gather new bolt/eccentric cam/washer/nut
Apply anti-sieze copper grease to the bolts to prevent them siezing inside the bushes.
I fitted my new wishbone in this order:
1) Lower ball joint to hub carrier (and line up driveshaft at this point)
2) Suspension strut
3) Rear Bolt
4) Front Bolt
Once the bolts are through, make sure that the eccentric cams fit in exactly the same place as before. This is where the markings made in step 15 are useful.
Step 23
Hand tighten the four 24mm nuts. I am told that they should be torque tightened once the car is sitting on the ground at normal ride height.
Step 24
Connect the track rod end to the hub carrier. Torque tighten the 18mm nut.
step 25
Fit driveshaft nut but do not torque tighten just yet.
Step 26
Fit wheel and hand tighten the wheel nuts. Remove the axle stands and lower the car.
Step 27
Tighten hub nut to 230nm (used to be 275 but LR reduced it to 230 to put less stress on the bearings).
Step 28
Jack up the car. Remove the wheel and make a notch in the hub nut using a flat chisel.
Step 29
Fit wheel and nuts, lower the car and torque tighten wheel nuts to 140nm
Step 30
Fit centre cap
Step 31
Take the locking wheel nut out of the wheel Whistle Rolling with laughter
Step 32
Raise the suspension to normal ride height and torque tighten the four 24mm nuts.
Step 33
Attach the rear undertray (six 10mm bolts)
Step 34
Get the tracking done.
Give yourself a pat on the back - you've just saved yourself approx £400 Thumbs Up
Post #363424 Sat Nov 17 2012 1:43am
aljo
Excellent "how to" post Thumbs Up
stick it in the "wiki" Bow down awwww we dont have one on here ? Whistle
Post #363432 Sat Nov 17 2012 9:41am
kav1187
Thanks Aljo Very Happy
We don't have a wiki on here, however I have put together a definitive list of 'how to' guides at the top of the technical section:
http://rrsport.co.uk/forum/topic28424.html
If you know of any more let me know and I'll add them in Thumbs Up
Post #363440 Sat Nov 17 2012 11:01am
Paddi
Thanks Kav that's a great contribution. So much more useful than a manual Bow down Interesting to see you managed it with just the 'customer' jack and no phaffing about with removing fuses, turning on the hazards, opening a door etc etc (let's not start that debate again for God's sake). Yawn 2008 MY Java Black TDV8 HSE
Post #363463 Sat Nov 17 2012 4:18pm
kav1187
Thanks for the kind words Paddi Thumbs Up
I initially used the LR jack to lift it enough to get my 3 ton Halfords jack under the chasis as the side steps make it too low to get the big jack under the car Embarassed
I've found that if you lock it in access mode then it doesn't try to auto level. Either that or my sensors are Censored ed Laughing
Post #363536 Sun Nov 18 2012 12:11am
mse
Access mode locked will stop it auto levelling use that on the ferry Mike
2014 Facelift Discovery
Post #363554 Sun Nov 18 2012 11:02am
Tiny Timmy
Excellent pics and description Thanks , just what this Forum is about, well done Razz Thumbs Up Thumbs Up
Post #363615 Sun Nov 18 2012 9:56pm
kluklut
United Kingdom 2007 Range Rover Sport TDV6 HSE Adriatic Blue
Wow! thanks for this. Really astonishing what such you can accomplish with so few tools!
Post #372447 Wed Feb 06 2013 2:12pm
I don't fancy doing this on the road side (no driveway) so I'm sadly paying someone else to do mine next week. They're charging for 2 hours work to do it (total of £540 +VAT!!)
I might ask them to do the track rod ends at the same time just for the hell of it. Not sure. 2012 SDV6 - it's missing a couple of cylinders
Post #372463 Wed Feb 06 2013 4:44pm
Bodsy
Site Sponsor
If youre having the track rod ends changed, it's definately worth changing the inner track rods as well. Inners seem to wear twice as much as the ends. Thumbs Up
About £100 for both sides (plus fitting of course) Thumbs Up
Nice right up Kav. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #372494 Wed Feb 06 2013 11:19pm
kav1187
Thanks Chaps - I've got the inner track rods too so when I do my driver's side I'll take some pics and add to the guide Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
Post #372728 Fri Feb 08 2013 2:38pm
Disco_Mikey
The inner track rods are around £15 each, and T.R.E's another £15 each or so. If you are interested in buying the kit, it is actually cheaper to buy all the parts individually
That said, I have never had to replace the inner track rods on an RRS. Done hundreds on D3's, but never an RRS...
Post #372941 Sun Feb 10 2013 5:06pm
Just got mine back from the dealer. Took 2 days to replace the front lower arms. Apparently much "swearing and throwing of hammers" was involved. They had to cut them off in the end. Glad I didn't try it myself and also glad it was done on a price so the extra hours involved didn't cost me. Thumbs Up
I asked them to look at the track rod ends. They inform me that they're ok and don't need replacing but I wonder if that's just because they've seen enough of my vehicle for now... Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #373522 Thu Feb 14 2013 6:39pm
Disco_Mikey
2 days? Shocked
It takes 2 hours to replace them... whether they need cutting off or not
Post #373552 Fri Feb 15 2013 6:58am
Fair enough. Judging by some of their work previously I could see them spending a day trying to undo one bolt... 2012 SDV6 - it's missing a couple of cylinders
Post #373561 Fri Feb 15 2013 10:05am
