Home > General > Cracked Sat Nav Screen
richheal
Hi all,
I managed to crack the screen on my 2006 model (long story!). Is there anyway this can be replaced, and if so does anyone recommend a supplier (I'm based in London), or would the whole unit need replacing?
Thanks and regards,
Richard
Post #382351 Tue May 07 2013 10:20am
Bodsy
Site Sponsor
You can usually get the screensnon eBay or from a breakers. They're not coded and are relatively straightforward to do. Although getting the side vents off can be a pain on a RRS, but all very do-able Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #382353 Tue May 07 2013 10:26am
http://www.ebay.co.uk/itm/Range-Rover-Spor...143wt_1402
Post #382366 Tue May 07 2013 11:22am
simple1
Rolling with laughter Rolling with laughter blokes a comedian. £200 quid for TV in motion, thought that was a case of cutting one wire. Must use gold plated side cutters Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #382385 Tue May 07 2013 3:04pm
mse
I'm almost sure it's not cutting a wire Thumbs Up Mike
2014 Facelift Discovery
Post #382404 Tue May 07 2013 4:12pm
sparky8181
I may be wrong but thought cutting the wire was to trick it into thinking its a FF system for audio on sat nav screen etc, I thought TV on the move was an software update?
Post #382406 Tue May 07 2013 4:26pm
mse
Agree it's some software or hardware software bodge to make it worth Mike
Post #382408 Tue May 07 2013 4:36pm
simple1
Well I have been known to be wrong Whistle
I know with Audi systems, it's one wire and the TV works on the move, way off target with a wire from
Gear sector sending message to TV to say its in Park Embarassed 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #382410 Tue May 07 2013 5:37pm
sparky8181
I had a similar thing with a sat nav tv dvd system in one of my vans, we had to connect a wire to ground to trick it into thinking the hand brake was on.
Post #382414 Tue May 07 2013 5:54pm
mse
On the 2013 its more speed dependent, so its not a simple on off...its disable picture (not sound) below a certain speed (4 or 5 mph) Mike
Post #382415 Tue May 07 2013 5:56pm
My 2012 model TV works on the move Wink Then again, i do have the dual view TV. Thumbs Up
Post #382435 Tue May 07 2013 8:47pm
mse
Rolling with laughter Mike
Post #382525 Wed May 08 2013 5:59pm
