Home > General > Cracked Sat Nav Screen |
You can usually get the screensnon eBay or from a breakers. They're not coded and are relatively straightforward to do. Although getting the side vents off can be a pain on a RRS, but all very do-able Bodsys Brake Bible
Tue May 07 2013 9:26am |
Tue May 07 2013 10:22am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
blokes a comedian. £200 quid for TV in motion, thought that was a case of cutting one wire. Must use gold plated side cutters 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue May 07 2013 2:04pm |
I'm almost sure it's not cutting a wire Mike 2014 Facelift Discovery |
Tue May 07 2013 3:12pm |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 |
I may be wrong but thought cutting the wire was to trick it into thinking its a FF system for audio on sat nav screen etc, I thought TV on the move was an software update? |
Tue May 07 2013 3:26pm |
Agree it's some software or hardware software bodge to make it worth Mike
Tue May 07 2013 3:36pm |
Well I have been known to be wrong
Tue May 07 2013 4:37pm |
I had a similar thing with a sat nav tv dvd system in one of my vans, we had to connect a wire to ground to trick it into thinking the hand brake was on. |
Tue May 07 2013 4:54pm |
On the 2013 its more speed dependent, so its not a simple on off...its disable picture (not sound) below a certain speed (4 or 5 mph) Mike
Tue May 07 2013 4:56pm |
My 2012 model TV works on the move Then again, i do have the dual view TV. |
Tue May 07 2013 7:47pm |
Mike
Wed May 08 2013 4:59pm |
