![]() | Home > General > LPG |
Why not give JE engineering a call if they are the experts, i'm sure they will tell you all you need to know. |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Try a search, there was someone on here a few years ago (around 2008 or 9) who had an LPG converted V8 (can't remember if it was an S/C) and he reckoned it was fine. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
kp Member Since: 18 Jan 2012 Location: Ex Bashing! Posts: 91 ![]() |
If you look on the FF site there are a few that run it but Flashlube is a must unless you do what JE want you to do and remove the heads and put hardened valve stem seals and seats and IIRC new valves as well...
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
Yeah there seems to be a few on eBay for sale and I'm tempted but a few have said lpg and charger engine is a no no, not much information to why not hasn't been posted (or I've not seen it).
DC_Supercharged Member Since: 14 Aug 2013 Location: Warwickshire Posts: 27 ![]() ![]() ![]() |
I have a 4.2 running on LPG - it's fitted with a PRINS LPG system including Flashlube and runs perfect.
PaulHH Member Since: 24 May 2013 Location: Highlands Posts: 98 ![]() ![]() ![]() |
I have one running on LPG. The car has done 33000 miles on LPG with the last owner and its running fine with me.
What LPG system have you got fitted PaulH? I don't have any issues with performance - I can't even tell the difference when it's running on petrol or LPG! |
I must admit I haven't a clue what type is fitted. The ECU looks like the one that was fitted to my FFRR but it has a different fuel switch. This one has a wee green/red light top right corner and a row of lights on the left side but I couldn't see the label. it was fitted nicely but they didn't fit it allowing the engine cover to be refitted which is a shame.
best way to find out what LPG system you have is to look at the injectors - the brand is normally printed on the side of them. |
imb111 Member Since: 30 Nov 2012 Location: UK Posts: 28 ![]() ![]() |
Where does the mounting point get cut into on the RRS?
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
and at that point you really have to think i'm saving sweet fa unless your going to drive it to the moon and back as a daily comute you might as well just use petrol as you will never re-coupe any of the outlay[/quote] |
imb111
