Home > General > Not so bullet proof TDV8 |
A bit surprised the brake pipes are looking dodgy on such a relatively young motor !! |
Fri Apr 19 2013 8:41pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4409 |
I have sent cars back to a main dealer to have the brake pipes replaced on cars still under the manufacturers 3 year warranty
Fri Apr 19 2013 9:06pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
The other bit of bad news is....
Sat Apr 20 2013 7:29am |
First off - the corrosion warranty should be explored - its 6 years and usually like to pay on holes rather than what you describe - but worth flagging, you never know on your list
Sat Apr 20 2013 9:31am |
Anti corrosion guarantee is for perforation only. So wont touch it until there are holes.
Sat Apr 20 2013 10:01am |
If they strip your engine right down then surely they will be able to turn whatever they need to turn to gain access. |
Sat Apr 20 2013 6:56pm |
This is a dealer Ady. They don't do stripping lol. That's dirty work
Sat Apr 20 2013 8:14pm |
Thats my point - at some point it will come apart As for the corrosion warranty - i did say about the hole part - but equally i had a defender (new) cleaned, prepared and waxoiled for surface corrosion, no perforations all done under warranty...doesnt hurt to ask/mention etc Mike 2014 Facelift Discovery |
Sat Apr 20 2013 9:40pm |
Refuse to get further stressed by the entire episode. Dealer tasked with doing a job and am sure they will
Sun Apr 21 2013 7:43am |
I dont blame you on that score!! Mike
Sun Apr 21 2013 5:30pm |
Well...... The new engine and turbos have been fitted
Wed Apr 24 2013 5:24pm |
kp Member Since: 18 Jan 2012 Location: Ex Bashing! Posts: 91 |
I would honestly get shut of it after all the faults you have been through and crud reading this thread!
Thu Apr 25 2013 12:17pm |
Thought about getting rid but heart over rules brain as when this car goes well, it is a pleasure. Not sure why they suffer more than full fat but there is obviously an issue which is why they didn't fit the V8 to facelift models. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Apr 26 2013 6:59am |
The beasty is up and running when I left workshop the brakes were being bled and wheels put back on. They emptied four Ltrs of 5/30 out of the exhaust system so hope to have it MOT'd in morning testing cats and then four wheel align and off to body shop to remove remainder or compound scars and fitting scratches. 's
Mon Apr 29 2013 5:32pm |
