Home > Faults & Fixes > Replacing EGR Valves 2007 Sport HSE
jack508
United Kingdom 2007 Range Rover Sport TDV6 HSE Luxury Java Black
Hi All
Any ideas what i should be paying to have the EGR valves supplied and fitted to my Sport HSE?
Post #376780 Wed Mar 13 2013 6:51pm
StuRRS
2007 Range Rover Sport TDV6 HSE Java Black
PM sent Stu
2023 RRS p440e SE Dynamic
2018 Discovery 5 SDV6 HSE Santorini gone
2014 SDV6 HSE Santorini gone
2007 TDV6 HSE Java gone
2003 Discovery TD5 ES gone and missed
2008 Q7 gone
2005 X5 gone
2003 X5 gone
2000 Freelander 2.5 V6 gone- not missed!!
Post #376782 Wed Mar 13 2013 7:02pm
jack508
My local indy who services my car said this is a tough job, his understudy chipped in with "this will be around �1500 to do it".
Post #376789 Wed Mar 13 2013 7:11pm
baxc
pm sent
Post #376790 Wed Mar 13 2013 7:17pm
Disco_Mikey
Shocked Rolling with laughter
Valves are �150 each, and 2 hrs a side. Try �500 Thumbs Up
Post #376878 Thu Mar 14 2013 9:35am
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Rolling with laughter Rolling with laughter
Or try DIY...have a look at the link at the bottom Mikey's signature Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #376925 Thu Mar 14 2013 3:16pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi, Disco Mikey is the 2008 HSE the same price. Also My Fault Code is PO405,would that be left or right side unit? itisme
Post #377966 Sat Mar 23 2013 3:07pm
Disco_Mikey
Yes Thumbs Up
Needs to be plugged in, and the live readings checked to determine which valve is at fault
Post #377968 Sat Mar 23 2013 3:34pm
harrygh60
Disco_Mikey wrote:
Yes Thumbs Up
Hi Disco Mikey, I have pluged in and got a fault code PO405. The readout for this code is Exhaust Gas Recirculation EGR Valve position sensor A. Low input. Check if there is a wiring fault. Is (A.) Offside or Nearside .? Fault code PO406 Is sensor (B)Cheers Bow down itisme
Post #379055 Fri Mar 29 2013 10:09am
harrygh60
harrygh60 wrote:
Disco_Mikey wrote:
Yes Thumbs Up
Sorry PO406 is sensor (A ) High Input. PO407 is Sensor (B) itisme
Post #379082 Fri Mar 29 2013 3:27pm
Kiwi Graham
New Zealand 2007 Range Rover Sport TDV6 SE Stornoway Grey
Had mine replaced by an independant $1,100 Smile
Post #379530 Wed Apr 03 2013 8:20pm
Disco_Mikey
Did you check the live readings? There are 3 position sensors in each valve...
Live readings would show up which valve is moving, and which is stuck.
FWIW, a lot of people replace them in pairs. If one has failed, the other is probably not far behind it
Post #379551 Thu Apr 04 2013 7:07am
