![]() | Home > Faults & Fixes > Replacing EGR Valves 2007 Sport HSE |
StuRRS Member Since: 18 Jan 2013 Location: Gloucestershire Posts: 92 ![]() ![]() |
PM sent Stu
jack508 Member Since: 14 Aug 2012 Location: Liverpool Posts: 11 ![]() ![]() ![]() |
My local indy who services my car said this is a tough job, his understudy chipped in with "this will be around £1500 to do it". |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
pm sent |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4446 ![]() ![]() ![]() |
![]() ![]() Valves are £150 each, and 2 hrs a side. Try £500 ![]() |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Hi, Disco Mikey is the 2008 HSE the same price. Also My Fault Code is PO405,would that be left or right side unit? itisme |
Yes |
Hi Disco Mikey, I have pluged in and got a fault code PO405. The readout for this code is Exhaust Gas Recirculation EGR Valve position sensor A. Low input. Check if there is a wiring fault. Is (A.) Offside or Nearside .? Fault code PO406 Is sensor (B)Cheers ![]() |
Sorry PO406 is sensor (A ) High Input. PO407 is Sensor (B) itisme |
Kiwi Graham Member Since: 06 May 2012 Location: Auckland, New Zealand Posts: 24 ![]() ![]() ![]() |
Had mine replaced by an independant $1,100 |
Did you check the live readings? There are 3 position sensors in each valve...
