Home > General > 6m wait + purchase = oh ye...h? |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
Picked up my new motor after looking hunting for some time.
Fri Mar 22 2013 9:29pm |
do you mean use the satnav screen? |
Fri Mar 22 2013 9:45pm |
Sat nav screen yes but not in navigation mode. In 4x4 info mode where the wheels and chassis are illustrated. RRS gone
Fri Mar 22 2013 10:21pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Mar 22 2013 10:31pm |
looks pretty kosher. does this mean not actual fault and just sensor? pls say yes
Fri Mar 22 2013 11:38pm |
If it was a sensor you would have one wheel reading a different colour. Needs a fault code reading I fear. Check the fluid anyway, if it is low you will need to check why. That's where the bad news starts, but won't spoil your Friday night..... 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Mar 22 2013 11:44pm |
Fri Mar 22 2013 11:59pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Check the battery, check the alternator. If both ok then it's time to check other things. Definitely requires the codes reading to see if anything is showing there. 2012 SDV6 - it's missing a couple of cylinders
Sat Mar 23 2013 12:24am |
the dealer hooked it up to their fault reader and nothing showed up hence why they said red herring and just cycle ignition to "reset it" |
Sat Mar 23 2013 12:26am |
Stick a meter across the battery and read the voltage when engine is off and when idling immediately after starting. 2012 SDV6 - it's missing a couple of cylinders
Sat Mar 23 2013 12:36am |
ok will pick one up tomorrow and test this.
Sat Mar 23 2013 12:43am |
Yep. Ideal. Voltage should be 12 at rest and anything up to 15 when running.
Sat Mar 23 2013 7:26am |
im not sure what they used. looks like a tablet with handles. not sure if it was official code reader. will find out tomorrow.
Sun Mar 24 2013 1:54pm |
Sounds a little bit low but not by miles. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Mar 24 2013 2:37pm |
