![]() | Home > General > 6m wait + purchase = oh ye...h? |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
Picked up my new motor after looking hunting for some time.
will post more pics but right now got more important things to worry about, such as the problem described in here: http://www.rrsport.co.uk/forum/topic19047....+cornering I pointed this out during the test drive but the lead technician's diagnostic tool didn't return any fault codes. They cycled the ignition back on and it went away and was told it's a red herring probably stemming from when they had the wheels refurbished and that if it happens again just cycle the ignition. We tested the suspension control and it was smooth so I took their word for it. Soon as I hit the motorway it came back on for the duration. Did pit stop and it disappeared after i set off again only to reappear later. Booked in to the nearest 4x4 specialist recommended by the indy dealer's warranty company. Not sure what to expect as every thread ive read on this topic has resulted in different root causes. not going in until next week, so in the meantime would really appreciate some advice on anything i can check to determine if it is a red herring or if it is indeed not fit to drive. also just noticed that rear tyre looks flat...not the greatest start ![]() |
do you mean use the satnav screen? |
Sat nav screen yes but not in navigation mode. In 4x4 info mode where the wheels and chassis are illustrated. RRS gone
looks pretty kosher. does this mean not actual fault and just sensor? pls say yes
will check fluid tomorrow. |
If it was a sensor you would have one wheel reading a different colour. Needs a fault code reading I fear. Check the fluid anyway, if it is low you will need to check why. That's where the bad news starts, but won't spoil your Friday night..... 2x TDV6. SE and HSE. Both returned to sender with issues👀
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Check the battery, check the alternator. If both ok then it's time to check other things. Definitely requires the codes reading to see if anything is showing there. 2012 SDV6 - it's missing a couple of cylinders
the dealer hooked it up to their fault reader and nothing showed up hence why they said red herring and just cycle ignition to "reset it" |
Stick a meter across the battery and read the voltage when engine is off and when idling immediately after starting. 2012 SDV6 - it's missing a couple of cylinders
ok will pick one up tomorrow and test this.
Yep. Ideal. Voltage should be 12 at rest and anything up to 15 when running.
im not sure what they used. looks like a tablet with handles. not sure if it was official code reader. will find out tomorrow.
Sounds a little bit low but not by miles. 2x TDV6. SE and HSE. Both returned to sender with issues👀
