Home > Maintenance & Modifications > New Procedure for fixing Knocking Suspension
Page 5 of 6 <123456>
Didn't realise they let children in here too... Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #341715 Sat Apr 28 2012 10:55pm
Supacat
JC1 wrote:
johnhampton wrote:
I have a MY10 RRS and appear to have a knocking noise coming from the front right suspension when driving on an uneven road. Anyone else had this problem on a MY10?
Yes i have, if its an early one (pre Feb/March ish) it wont have mass dampers fitted, lookers put mass dampers on mine and it stopped the knocking......................but i do seem to be getting another knock on the front much like last time Confused It will be due its first service soon so will get it checked.
Are you saying the mass dampers delevoped as a fix and retro fitted to earlier cars was not incorporated into the standard build for later cars?
Post #341725 Sun Apr 29 2012 8:17am
n_buyabis
Kuwait 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
Hello guys,
Just called in the dealership (Kuwait) regarding the bulletin, they directly said NO they never heard of it.
I escalated it to land rover middle east and awaiting their reply.
MY: 2006, HSE, Range rover sport. VIN:6A939781
can anyone advise if i fall within the VIN range.
Br
Najeeb Buyabis
Post #342169 Wed May 02 2012 10:37am
b3nle
United Kingdom 2005 Range Rover Sport Supercharged Santorini Black
I had a knock on my S/C RRS, changed both the lower arms and it was sorted.......hope this helps?
Post #354415 Wed Aug 22 2012 9:33am
I had new anti roll bar bushes at the front and it got rid of the knock.
Also had new bushes at the rear when they changed the rear dynamic ARB. This made the rear quiet too. 2012 SDV6 - it's missing a couple of cylinders
Post #354420 Wed Aug 22 2012 10:57am
erikh
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
So I am experiencing this issue now with my ´06 RRS HSE, will contact dealer and hear what they say.....
Post #371472 Tue Jan 29 2013 9:08pm
erikh
Just got a reply from dealer, they agreed this might indeed be a warranty repair and will check the car Feb. 7th. Will keep you posted.
Erik
Post #371528 Wed Jan 30 2013 9:50am
jack.bauer
one mechanic that inspected my car and recommended changing front ARB bushes, also said they would remove two components that contribute to the noise and actually serve no purpose. in fact Land Rover recommend these are removed. does anyone know what he was referring to. he did tell me but it escapes me now (there were so many problems we discussed with the car, ive forgotten what this was) 07 TDV8 + BAS map
Post #392449 Thu Aug 22 2013 12:12am
Could be the harmonic damper masses. Also, one of the early "fixes" for suspension noise was to remove a couple of the body - chassis dampers. These are dampers connecting the body to the chassis frame and supposedly act as a path for suspension noise. 2012 SDV6 - it's missing a couple of cylinders
Post #392459 Thu Aug 22 2013 7:58am
jack.bauer
what about "links" on the arb
what do they do? could they be the parts lr recommending removing 07 TDV8 + BAS map
Post #393075 Wed Aug 28 2013 10:43pm
The ARB links connect the ARB to the suspension wishbones. If you remove the links the ARB ceases to function. 2012 SDV6 - it's missing a couple of cylinders
Post #393080 Wed Aug 28 2013 11:21pm
jack.bauer
ok thats not it then, sounds like the dampers that you mentioned previously. will find out tomorrow
thanks dude 07 TDV8 + BAS map
Post #393082 Wed Aug 28 2013 11:24pm
The ARB bushes wear. It's a fact of RRS life. Removing the body-chassis dampers just removes a noise path, it doesn't cure the issue of worn ARBs. The ARBs need to be replaced if there's a knoock coming from single wheel deflections from pot holes. 2012 SDV6 - it's missing a couple of cylinders
Post #393084 Wed Aug 28 2013 11:31pm
jack.bauer
yep, the car is in for exactly that, the ARB bushes are being replaced.
i was hoping to also remove these dampers simply so they stop the noise path in case something else is contributing to the knocking other than the arb bushes.
what ive learnt so far is there are a number of root causes that exhibit the same knocking sound. it could be one of them alone or a combination of all. i also know that some cars have gone through the full monty including entire roll bar replaced and still have some knocking noise that cannot be cured and so can only be camouflaged by making it inaudible, for example by cutting off the noise path. just trying to figure out if thats worth doing if the car is in for bushes replacement. it could very well be that its not needed and the new bushes cure the problem in my particular case. 07 TDV8 + BAS map
Post #393085 Wed Aug 28 2013 11:42pm
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
So.......say I have purchased a RRS on an 07 plate from a main dealer and still have 8 months full warranty on it, will LR carry out this clunking suspension technical bulletin for free?
I think i have this on my vehicle and did mention it to the salesman but he said "that's normal".
I'd like to get it sorted before the warranty runs out. Is this the same as a recall?
Gaz.
Post #399033 Sat Oct 19 2013 2:03pm
