Home > Maintenance & Modifications > New Procedure for fixing Knocking Suspension |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
Are you saying the mass dampers delevoped as a fix and retro fitted to earlier cars was not incorporated into the standard build for later cars? |
Sun Apr 29 2012 8:17am |
n_buyabis Member Since: 02 May 2012 Location: Kuwait Posts: 1 |
Hello guys,
Wed May 02 2012 10:37am |
b3nle Member Since: 24 Jul 2012 Location: nr bridgend Posts: 10 |
I had a knock on my S/C RRS, changed both the lower arms and it was sorted.......hope this helps? |
Wed Aug 22 2012 9:33am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
I had new anti roll bar bushes at the front and it got rid of the knock.
Wed Aug 22 2012 10:57am |
erikh Member Since: 15 Mar 2012 Location: Stavanger Posts: 24 |
So I am experiencing this issue now with my ´06 RRS HSE, will contact dealer and hear what they say..... |
Tue Jan 29 2013 9:08pm |
Just got a reply from dealer, they agreed this might indeed be a warranty repair and will check the car Feb. 7th. Will keep you posted.
Wed Jan 30 2013 9:50am |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
one mechanic that inspected my car and recommended changing front ARB bushes, also said they would remove two components that contribute to the noise and actually serve no purpose. in fact Land Rover recommend these are removed. does anyone know what he was referring to. he did tell me but it escapes me now (there were so many problems we discussed with the car, ive forgotten what this was) 07 TDV8 + BAS map |
Thu Aug 22 2013 12:12am |
Could be the harmonic damper masses. Also, one of the early "fixes" for suspension noise was to remove a couple of the body - chassis dampers. These are dampers connecting the body to the chassis frame and supposedly act as a path for suspension noise. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 22 2013 7:58am |
what about "links" on the arb
Wed Aug 28 2013 10:43pm |
The ARB links connect the ARB to the suspension wishbones. If you remove the links the ARB ceases to function. 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 28 2013 11:21pm |
ok thats not it then, sounds like the dampers that you mentioned previously. will find out tomorrow
Wed Aug 28 2013 11:24pm |
The ARB bushes wear. It's a fact of RRS life. Removing the body-chassis dampers just removes a noise path, it doesn't cure the issue of worn ARBs. The ARBs need to be replaced if there's a knoock coming from single wheel deflections from pot holes. 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 28 2013 11:31pm |
yep, the car is in for exactly that, the ARB bushes are being replaced.
Wed Aug 28 2013 11:42pm |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
So.......say I have purchased a RRS on an 07 plate from a main dealer and still have 8 months full warranty on it, will LR carry out this clunking suspension technical bulletin for free?
Sat Oct 19 2013 2:03pm |
