![]() | Home > Maintenance & Modifications > New Procedure for fixing Knocking Suspension |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
Many thanks.
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120 ![]() ![]() ![]() |
This might be a daft question but do Land Rover pay for this work to be done, |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
had the ARB replaced by land rover and the noise is still there |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
When you said "replaced ARB" - was it just the bushings ? I think the bushing would squeak when old - but it would have to be very worn for the roll bar itself to knock against the chassis mounting point ? Did you ask them to keep the old bushings to see their condition. I had a clunk coming from the front suspension in my BMW E46 - driving straight at 30-40MPH down uneven road. I saw an episode of wheeler/dealers where they replaced sway bar drop links to fix a similar problem. I purchased a couple of $18 Delphi drop links - had them installed - did the ARB bushings at the same time - and fixed the problem. Old bushings looked fine - and it was hard to tell how worn the drop links were - but if the bushing in there is worn - you will have metal to metal contact in the link - and this will cause a knocking noise. I think those parts are cheap on the RRS too - and should be replaced (on standard - not active system at least) - not just the roll bar bushings themselves.
You guys that have had this done successfully and now have a perfectly quiet car, how much did you pay for this fix? |
mal1721 Member Since: 27 Nov 2020 Location: Hampshire Posts: 20 ![]() ![]() |
Has no one else had these issues since the last thread some years ago? I have an annoying clunking which no one can seem to find, in fact the 3 garages I've tried here in Hampshire UK have very little interest and just shrug their shoulders. |
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 ![]() ![]() ![]() |
Gaz
OOPS, sorry replied by mistake |
Hi Mal,
Sorry I should have included a link to the technical bulletin
Lee, thats brilliant thank you. Yo have given me somewhere to start and I've downloaded the bulletin, priced the parts and have someone looking at it who is a Range Rover specialist on Thursday.
