![]() | Home > Technical > Fuel burning heater not starting |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Looks like mine is |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Shakeapaw, have you checked the fuse? It's in the fuse box in the engine bay, no 28 I believe. Wait till the car is in sleep mode then pull it out and put it back in. If it has locked up then this should clear it.
Cheers for the reply, i did all of the above last year as it was locked out when i bought it. So its nothing that can be checked or reset im afraid, its dead 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 ![]() ![]() ![]() |
I would try what rob and kav have done if not at least go to a decent independant who might charge �35 and reset the error code its probably just locked out get it reset and purged or speak to bodsy on here i dont know where you are based but im sure someone could try a reset and purge before you go spending big money on a new unit close to a grand i would think "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
pm sent "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
erikh Member Since: 15 Mar 2012 Location: Stavanger Posts: 24 ![]() ![]() ![]() |
Might need a new burner? Bloke in Norwegian lrforum changed his no problemo. |
I do have the 1533 oval timer inside the car and there should be a cable for this to be bought and then plug into my pc? Problem is I do not know what this cable is called... |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Kav Which drivers did you use?? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
So it seems I already have the red wire in the FBH (Looks orange though in the pic due to flash), does this mean I can just plug the OBD2 to USB cable inside car and diagnose with the Webasto software?
The red cable (orange in your case |
Your probably right, seeing I do have the 1533 timer. Then I would need to connect to the timer cable pin inside, but with what? I have ordered the OBD2 cable anyways as I am sure it will come in handy ![]() |
Here�s the back of my OBD port in the car, any clues as to wether or not the right cable is in the right place here?
Ok,
Rob - I just plugged it into my laptop which is running windows 7 and it automatically installed a driver. I assume it is a generic one as my XP laptop couldn't find one and was asking me to download one from the t'internet.
I just got a reply from Webasto that it is not free anymore........ Can someone please send me the software either via dropfile or email if it is not too large a file? Just pm me and we will work it out. Thanks in advance ![]() |
