![]() | Home > Technical > Fuel burning heater not starting |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
Anyone know where to get a good deal on a remote controll kit for my heater? RRS 2006 2.7 HSE |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 ![]() ![]() ![]() |
Rob sent pm could you send me software as i cant get it cheers pete "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Software on its way to you ![]() |
Thanks Rob are you sending on disc? or email ? "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
I was sending it on a disc but if you want it before hand I can send you a dropbox link to D/L it from? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Disc is fine thanks Rob "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
erikh Member Since: 15 Mar 2012 Location: Stavanger Posts: 24 ![]() ![]() ![]() |
So after getting the OBD and adapter cable I tried inserting the +,- and WBUS cable in the contact that goes into the timer. + for +, minus for minus and WBUS for WBUS. OBD cable indicated power but nothing happened in software.
Did you check the +ve and -ve on the adapter cable were definitely going to the correct pins on the OBD plug? These things are massed produced in china and I didn't trust the wiring colors. You MUST verify the cables are going to the right pins using a multimeter before plugging into your car TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
I am afraid not - so then what? I mean the car starts but about the FBH I do not know as the timer gives no response/has no power.... What should I do? |
Start by checking fuses. not sure where the fuse is for the timer though? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Good question, I�ll do a search and see what comes up, unless someone in here knows. |
So an update, checked with multimeter the + gives no voltage, - is ok and WBUS seems ok too. So I guess I mistook the positive on the contact to the timer for the negative, that would trigger the fuse no?
Found the wires running down from the timer under the steering wheel (LHD btw). Methinks the picture here is of the fuse holder, but I am not sure. Is there a glass fuse in there perhaps? The + (positive) wire from the timer goes into this and the + is the one that doesn�t give a reading on the multimeter. The orange is the WBUS line and there is a black (negative) one there also.
Power issue solved, there was a fuse inside the holder that was DOA when I opened it.
Glad it was just a fuse Sounds like a good plan ![]() |
