![]() | Home > Technical > Fuel burning heater not starting |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
I'm in Essex. No idea if it will fire up when I start the car though...will let you know tomorrow |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 ![]() ![]() ![]() |
pm sent |
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 ![]() ![]() |
I have always wondered if mine worked as I never ever see smoke from the small exhaust. So the other day after the car had started I opened the bonnet and felt the consatina style pipe - what a nob!! Damn hot and burnt my hand. I assume it works then hey? |
At least you're sure it works |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Wow Kav, excellent and informative post and you have just saved me from posting the full "how to" post I intended to do.
Not critical but just makes a slightly neater solution ![]() |
There should be no reason why it doesn't ![]() Last edited by RobP on Wed Jan 23 2013 9:50pm. Edited 1 time in total |
cant wait to see it rob |
Rob - the neatest solution is to just run a wire from port 2 on the FBH connector to port 7 on the diagnostic socket under the steering wheel. That way you don't have to mess about with the battery or even have to open your bonnet.
Yes Kav you are right the ultimate solution is to populate the OBDII port in the car as you suggest with the K bus pin 7. A the moment I cant be ![]() ![]() the black plug contains +ve and -ve which i will replace with the croc clips i ordered at the same time for 99p ![]() All three wires that are needed ![]() |
Perfect! That'll do the trick nicely |
mjbrr Member Since: 31 May 2012 Location: Durham Posts: 81 ![]() ![]() ![]() |
Nice clear write up Kav.
As promised here are the details of the adapter lead I have just made up.
Tools needed: cutters, ratchet crimpers, soldering iron / solder & multimeter (essential to verify wires to pins your self)
Start with the lead ![]() This is the pin layout ![]() IMPORTANT ![]() ![]() Cut off the black plug and strip outer sleeve (this is for the power connections)
Extend the black and red cables by soldering and covering with heat shrink,
adding the fuse holder to the red 12v+ cable and add the croc clips to the leads
Now cut off white plug and strip a bit of outer sleeve. There are two wires and you will only need the one connected to pin 7 in the main plug.
Using the multimeter I identified this to be the black lead so simply snipped the red lead off. However you should verify this is the right lead your self in case your lead is wired differently ![]()
I extended the cable by soldering on another small length of wire to which I added the male crimp connector and then heat shrink for neatness
This is the finished item plugged into the OBDII USB
If you follow this part from Kavs instructions to install the single wire from the forum shop
And the finally add the female crimp terminal to the bare end of that wire. To connect the OBDII lead now all you need to do is attach the croc clip wires to the battery terminals and plug together the male / female connectors ![]() It was too late to test the lead tonight but I will report back as soon as I have. TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten Last edited by RobP on Mon Feb 04 2013 11:13pm. Edited 3 times in total |
Great post rob |
Fantastic write up mate |
erikh Member Since: 15 Mar 2012 Location: Stavanger Posts: 24 ![]() ![]() ![]() |
So a really stupid question perhaps - if I buy the Faultmate FCR it will only let me read and clear codes, will that be good enough?
