Home > Technical > Fuel burning heater not starting |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
I'm in Essex. No idea if it will fire up when I start the car though...will let you know tomorrow Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section
Wed Jan 23 2013 6:08pm |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 |
pm sent |
Wed Jan 23 2013 6:11pm |
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 |
I have always wondered if mine worked as I never ever see smoke from the small exhaust. So the other day after the car had started I opened the bonnet and felt the consatina style pipe - what a nob!! Damn hot and burnt my hand. I assume it works then hey? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
At least you're sure it works
Wed Jan 23 2013 6:37pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Wow Kav, excellent and informative post and you have just saved me from posting the full "how to" post I intended to do.
Wed Jan 23 2013 8:46pm |
There should be no reason why it doesn't TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten Last edited by RobP on Wed Jan 23 2013 8:50pm. Edited 1 time in total |
Wed Jan 23 2013 8:50pm |
cant wait to see it rob |
Rob - the neatest solution is to just run a wire from port 2 on the FBH connector to port 7 on the diagnostic socket under the steering wheel. That way you don't have to mess about with the battery or even have to open your bonnet.
Wed Jan 23 2013 9:11pm |
Yes Kav you are right the ultimate solution is to populate the OBDII port in the car as you suggest with the K bus pin 7. A the moment I cant be to run the lead back into the cabin but if it becomes a regular need I can think again the black plug contains +ve and -ve which i will replace with the croc clips i ordered at the same time for 99p and the white plug has K bus (pin 7 in OBDII plug) and L bus (pin 15 in OBDII plug) i will simply ignore the L bus cable and just use the K bus one. All three wires that are needed TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Wed Jan 23 2013 9:25pm |
Perfect! That'll do the trick nicely Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section
Wed Jan 23 2013 9:41pm |
mjbrr Member Since: 31 May 2012 Location: Durham Posts: 81 |
Nice clear write up Kav.
Wed Jan 23 2013 11:03pm |
As promised here are the details of the adapter lead I have just made up.
And the finally add the female crimp terminal to the bare end of that wire. To connect the OBDII lead now all you need to do is attach the croc clip wires to the battery terminals and plug together the male / female connectors It was too late to test the lead tonight but I will report back as soon as I have. TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten Last edited by RobP on Mon Feb 04 2013 10:13pm. Edited 3 times in total |
Thu Jan 24 2013 11:25pm |
Great post rob "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
Thu Jan 24 2013 11:40pm |
Fantastic write up mate
Fri Jan 25 2013 12:04am |
erikh Member Since: 15 Mar 2012 Location: Stavanger Posts: 24 |
So a really stupid question perhaps - if I buy the Faultmate FCR it will only let me read and clear codes, will that be good enough?
Fri Jan 25 2013 4:03pm |
