![]() | Home > Technical > Fuel burning heater not starting |
I'm Bodsy....... |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 ![]() ![]() ![]() |
Rob let us know if it works and maybe list the items you have purchased and some photos etc it may well help others on here |
just had a look at this on the disco 3 site you said waaaaaaaaaaaaaayyyyyyyyyyyyy to complicated for me |
I'm sure Bodsy would be able to sort my issue but
Sounds good let us lnow |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
Yep I'm in the same boat. I've bought the cables from Martin and need to connect it all up. I'm going to make it so that the cables are connected to my OBD port so that I don't have to mess around in the engine bay every time I want to reset the FBH. Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section |
Got up this morning mine FBH isnt working again going back to get it reset if these leads work does anyone fancy making one up for me as im too thick to do it myself |
It's literally as simple as plugging a couple of wires into the back of a couple of connectors. Hardest thing is figuring out where to run the wires from the inside of the car to the FBH...does anyone have any suggestions? Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section |
Nah, I'll still talk to you ![]() ![]() Will be down your way In Feb if thats any use ![]() Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Glad to hear I didn't completely ![]() If I haven't sorted it myself by Feb I may take you up on that offer ![]() |
Based on the Disco3 post it is quite simple but that thread has got a bit deep and long. As I said once I get my leads I will post a how to guide along with details of what leads I got, links to the ebay items, and how I made them up. Once I have posted a simplified how to, then let me know if you still cant do it! TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Thanks Rob i will do had all ecu parramiters re set again today still didnt fire up its now |
Obviously I haven't got the BAS unit or I wouldn't be in this situation ![]() Fitting is basically three wires. + battery , - battery and w bus (terminal 2) connection at FBH. Exactly the same connections as the lead I will be making up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
I hope it works you have your first customer |
