Home > Technical > Fuel burning heater not starting |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Hi all
Sat Jan 19 2013 1:14pm |
If your car hasnt got the voltage it wont start...this allows you to start the car Mike
Sat Jan 19 2013 1:24pm |
I could understand this if I had the remote pre heater, but mine is just the standard one that helps the engine to warm up quicker once started. Surely the heater isn't looking for voltage until the engine starts at which point the alternator is supplying power so it should be able to start? If not does any one know what the minimum voltage the heater is looking for before it kicks in? I have no problems starting the car or any of the normal low battery signs TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Sat Jan 19 2013 3:04pm |
Just found THIS guide on the D3 site and it suggests anything below 10.25v will stop it but also it goes into lockout after three failed starts.
Sat Jan 19 2013 3:36pm |
Mike
Sat Jan 19 2013 4:43pm |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 |
sounds like its locked out just had mine reset by a local specialist who did my timing belt he didnt charge me and it now works fine |
Sat Jan 19 2013 6:20pm |
So this morning I pulled out fuse 28 and left it out for about 20 mins to ensure car had gone to sleep.
Sun Jan 20 2013 11:58am |
a good independant will do it it will take 3 mins to do its locked out |
Sun Jan 20 2013 12:15pm |
I tried this also and it didnt work for me as i say it was locked out and my local specialist reset it free of charge it takes literally 3 minutes to do |
Sun Jan 20 2013 1:21pm |
There's two elements to this issue really.
Sun Jan 20 2013 2:31pm |
Bodsy is the man to sort it out he's a top bloke and knows his stuff thanks Ian for all my help |
Sun Jan 20 2013 2:40pm |
Well I have just read all 24 pages of THIS thread on Disco3. Based on that thread I have just ordered the parts off ebay to make up the Webasto diagnostic lead to hopefully clear the lock myself. Total spend £11 so if it doesn't clear its not a huge gamble
Sun Jan 20 2013 3:49pm |
The Webasto software with the right cable works really really well! You shouldn't have a problem running and purging and unlocking it. Quite good fun getting neighbours ready to call the fire brigade with the smoke you'll generate Bodsys Brake Bible
Sun Jan 20 2013 4:10pm |
Cheers Wiggs. If it doesn't work I may be in touch What version of the software do you recommend? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Sun Jan 20 2013 4:33pm |
