Home > Technical > Fuel burning heater not starting
Page 1 of 10 12345678910>
RobP
Hi all
Have noticed that my fuel burning heater does not start up anymore.
Previously it worked fine and I have no error messages on the dash, I thought it didn't kick in the other morning so today I opened the bonnet before starting and even at -3 it does nothing. 3/4 tank fuel so that's not the issue
Any checks or reset procedures I can try?
Also when I tried to close bonnet the catches hadn't reset so hot water, wd40 and a screwdriver to manipulate the catch were in order to get it moving properly
Cheers all TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370102 Sat Jan 19 2013 1:14pm
mse
If your car hasnt got the voltage it wont start...this allows you to start the car Mike
2014 Facelift Discovery
Post #370103 Sat Jan 19 2013 1:24pm
RobP
I could understand this if I had the remote pre heater, but mine is just the standard one that helps the engine to warm up quicker once started.
Surely the heater isn't looking for voltage until the engine starts at which point the alternator is supplying power so it should be able to start? If not does any one know what the minimum voltage the heater is looking for before it kicks in?
I have no problems starting the car or any of the normal low battery signs TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370123 Sat Jan 19 2013 3:04pm
RobP
Just found THIS guide on the D3 site and it suggests anything below 10.25v will stop it but also it goes into lockout after three failed starts.
So will pull fuse 28 to reset it and check battery voltage and see what happens tomorrow as I have just been out so engine will already be warm now TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370126 Sat Jan 19 2013 3:36pm
mse
Thumbs Up Mike
Post #370129 Sat Jan 19 2013 4:43pm
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
sounds like its locked out just had mine reset by a local specialist who did my timing belt he didnt charge me and it now works fine
Post #370147 Sat Jan 19 2013 6:20pm
RobP
Update
So this morning I pulled out fuse 28 and left it out for about 20 mins to ensure car had gone to sleep.
Tested voltage on battery at rest 11.77V so well within range.
Put fuse back in and started car. Still no joy
Any more suggestions or am I facing a dealer visit to plug it in and read the codes? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370199 Sun Jan 20 2013 11:58am
madmackie
a good independant will do it it will take 3 mins to do its locked out
Post #370200 Sun Jan 20 2013 12:15pm
MisterAdam
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Should pulling the fuse out and leaving it for a short period of time before putting it back in be enough to reset the unit? Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Previous: Mercedes CLS, BMW 330cd M sport, Nissan 200sx, Impreza STi, EP3 Civic Type R
Post #370203 Sun Jan 20 2013 1:14pm
madmackie
I tried this also and it didnt work for me as i say it was locked out and my local specialist reset it free of charge it takes literally 3 minutes to do
Post #370204 Sun Jan 20 2013 1:21pm
Bodsy
Site Sponsor
There's two elements to this issue really.
One is the locked out FBH and the other is old fuel in a previously locked out FBH.
When I do FBH resets for people it consists of
Fuel purge and test
Reset error codes
Run FBH sequence test.
It takes about 20 minutes to do both. The result is always a load of diesel smoke and that lovely familiar diesel FBH smell Mr. Green Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #370209 Sun Jan 20 2013 2:31pm
madmackie
Bodsy is the man to sort it out he's a top bloke and knows his stuff thanks Ian for all my help
Post #370210 Sun Jan 20 2013 2:40pm
RobP
Well I have just read all 24 pages of THIS thread on Disco3. Based on that thread I have just ordered the parts off ebay to make up the Webasto diagnostic lead to hopefully clear the lock myself. Total spend £11 so if it doesn't clear its not a huge gamble
Cheers Rob Thumbs Up TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370219 Sun Jan 20 2013 3:49pm
Bodsy
Site Sponsor
The Webasto software with the right cable works really really well! You shouldn't have a problem running and purging and unlocking it. Quite good fun getting neighbours ready to call the fire brigade with the smoke you'll generate Thumbs Up Bodsys Brake Bible
See it HERE
Post #370223 Sun Jan 20 2013 4:10pm
RobP
Cheers Wiggs. If it doesn't work I may be in touch Embarassed
What version of the software do you recommend? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #370229 Sun Jan 20 2013 4:33pm
