Home > Technical > 05 Supercharged - noise and gearbox delay
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Hi everyone, I have a couple of niggles with my 05 SC which you may be able to shed light on.
-First, when the car is cold, engaging drive isn't instant, it sometimes takes a couple of seconds for the car to move. Doesn't happen in reverse, just drive. i.e. I can reverse out of my drive, then stick it in D and a bootful of revs gets me nowhere until the box finally decides to get going.
-Second, when coasting to a stop from 40mph or so I hear a droning rumble noise that seems to come from the front.
* It's there whether I brake or not
* Changing gearbox to neutral makes no difference
* Revving engine makes no difference
Hope you have some ideas before I take it to a specialist.
"Roads ? Where we're going there are no roads." Back to the future.
Post #364083 Thu Nov 22 2012 4:24pm
The rumble may be bearing related, have you tried seeing if turning a corner effects the volume/tone?
The gearbox may just need a flush Thumbs Up RRS gone
Post #364086 Thu Nov 22 2012 4:42pm
Bodsy
Site Sponsor
Get underneat it and give the gearbox pivot lever a good dose of WD40, free it up, let the wd40 dry and then give it a good spray of grease. That should fix the drive delay.
Unless of coiurse you are low on ATF Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #364094 Thu Nov 22 2012 6:29pm
mrfrog
Thanks everyone, will check these over the week end Thumbs Up
Post #364240 Fri Nov 23 2012 7:04pm
Paddi
Have a look here:
http://www.ashcroft-transmissions.co.uk/in...ductId=222
Not specific to RRS but similar symptoms? 2008 MY Java Black TDV8 HSE
Post #364780 Wed Nov 28 2012 3:43pm
mrfrog
Sorry for not getting back sooner with updates, I hate tech questions being asked without a follow up Embarassed
Checked ATF, level ok.
Changed front right wheel bearing
Noise is still there, tried to check diff oil for colour but didn't have the right Allen key for the drain plug, now on order.
Didn't free/grease the selector, something to try when I am next under the car. Local specialist suggested a change of gearbox oil.
Post #369186 Sun Jan 13 2013 1:37pm
highfellzippy
Had this. Problem. On mine. Dealer changed selector lever Its a known problem.
Post #369209 Sun Jan 13 2013 5:17pm
mrfrog
Interesting, will look into it.
Post #369238 Sun Jan 13 2013 9:38pm
mrfrog
Finally got round to checking oil colour all round and all is good. ATF level fine with oil warm and engine running.
I however thought that since the right hand bearing showed signs of wear and replaced it, there was a chance the left hand one would be worn too. And indeed it is. Slight grinding noise when turning the wheel off the ground, not very pronounced but similar to what I hear when driving. Wiggling wheel while holding at 12 and 6 o'clock, there's a few mm of play.
New bearing on order. Hopefully this will cure it.
Done 78k miles just in case this is of interest to someone later one. Of course mileage will vary (pun intended)
Post #372662 Thu Feb 07 2013 10:11pm
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Ian where is the gearbox pivot lever out of interest have you got a picture cheers pete "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #372667 Thu Feb 07 2013 10:41pm
mrfrog
There's a silver foil-like cover under the gearbox (4x 8 or 10mm bolts hold it in place) which you need to remove. The lever is on the driver's side, more or less under the driver's seat.
I had a look at mine, wiggled it and found no play and sprayed penetrating fluid all over it.
I have found until recently that while the problem with gear selection was usually when first starting the car on cold days, it would also happen after driving a few miles whenever pulling out of a junction or roundabout after stopping although the gearbox oil was nice and warm.
It seems to have cured itself now, maybe a small blockage in the hydraulics, will probably flush the box oil at some point.
Post #372707 Fri Feb 08 2013 12:05pm
mrfrog
Wheel bearing replaced, noise all gone Mr. Green
I also noticed a slight squealing noise (whistle) which would stop when applying the brakes gently and still rolling which added to the duff bearing diagnosis.
Post #372906 Sun Feb 10 2013 11:28am
