Home > Technical > 05 Supercharged - noise and gearbox delay |
The rumble may be bearing related, have you tried seeing if turning a corner effects the volume/tone?
Thu Nov 22 2012 4:42pm |
Get underneat it and give the gearbox pivot lever a good dose of WD40, free it up, let the wd40 dry and then give it a good spray of grease. That should fix the drive delay.
Thu Nov 22 2012 6:29pm |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
Thanks everyone, will check these over the week end
Fri Nov 23 2012 7:04pm |
Have a look here:
Wed Nov 28 2012 3:43pm |
Sorry for not getting back sooner with updates, I hate tech questions being asked without a follow up
Sun Jan 13 2013 1:37pm |
highfellzippy Member Since: 06 Dec 2009 Location: yorkshire Posts: 255 |
Had this. Problem. On mine. Dealer changed selector lever Its a known problem. |
Sun Jan 13 2013 5:17pm |
Interesting, will look into it.
Sun Jan 13 2013 9:38pm |
Finally got round to checking oil colour all round and all is good. ATF level fine with oil warm and engine running.
Thu Feb 07 2013 10:11pm |
madmackie Member Since: 30 Sep 2012 Location: wigan lancashire Posts: 285 |
Ian where is the gearbox pivot lever out of interest have you got a picture cheers pete "Remember its easier to say sorry than it is to get permission " especially off the Mrs !! |
Thu Feb 07 2013 10:41pm |
There's a silver foil-like cover under the gearbox (4x 8 or 10mm bolts hold it in place) which you need to remove. The lever is on the driver's side, more or less under the driver's seat.
Fri Feb 08 2013 12:05pm |
Wheel bearing replaced, noise all gone
Sun Feb 10 2013 11:28am |
