Home > General > Parking sensors operation advice please
rangersport
Hi all,
Enjoying my new car that I got hold of on Sunday. Something odd I find is that when in reverse and parking, why does the car warn if the front sensors detect an object? e.g. a person walking past?
When reversing into a space why would I want to know if someone is walking in front of the car...every other car I have had only beeps in the direction of travel, i.e. front sensors if you are crawling forward, or rear sensors if you are reversing. Is this a fault, or are they all this abnormal?
Post #362093 Tue Nov 06 2012 1:48pm
In case the front swings close to an object Thumbs Up
All cars I've had bleeps on have warned front/rear obstructions regardless of the direction you are travelling.
My RRS has different audible tones so you can easily recognise if the problem is front or back Cool ON THE WAY: BMW F21 M140i
Post #362097 Tue Nov 06 2012 1:53pm
rangersport
Thanks for the reply bean.
I guess something I will get used to - and may well prove useful on a car this size! The merc I had definitely didn't do this!
O/T - but does anyone use the dipped wing mirror option on reverse? Sometimes as they dip so low I feel I may be missing something in my path - again need to get used to this. Certainly useful to save from kerbing marks!
I did try to experiment, in that if my mirrors in normal driving were HIGHER then on dip, they wouldn't lower as much and give me a more balanced view of the kerbs and of obstructions higher up, from my experiment, I think the ydip to same height no matter what the original setting is...
BTW : Absolutely LOVING the car! Awesome driving position, will be difficult to ever go back to a 'normal' car I think!
Post #362098 Tue Nov 06 2012 1:58pm
Morpheus-RRS
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Hi Rangersport,
Not sure which model year you have but on mine MY12 you can program the mirrors so that when you select Reverse then they will move to position which has been programmed by you (page 47 in my owners handbook)
Post #362104 Tue Nov 06 2012 2:10pm
Morpheus-RRS
Hi Rangersport,
Post #362105 Tue Nov 06 2012 2:11pm
I think you will find it useful tbh Thumbs Up
Re the reversing dip.
With reverse engaged and the mirrors dipped, adjust them to the position you would prefer.
They should remmeber that setting for next time Thumbs Up
Also rangersport, add you car model into your profile, will help people answer queries when something inevitably goes wrong Whistle Laughing ON THE WAY: BMW F21 M140i
Post #362110 Tue Nov 06 2012 2:27pm
mark hamster
also,you will notice the front senors are a higher pitch than the rear ones.! ii have programmed my mirrors to dip as i found it more easier to park.!
Post #362119 Tue Nov 06 2012 3:13pm
rangersport
Thanks all...will give a go at adjusting the level of the dip. It definitely is useful, but always fear at looking at the ground, I am missing something big - but I suppose that's what the sensors are for.
I have noticed the pitch difference too - and the front sensors, it sounds like the sound is from the front, so will not be too difficult to get used to.
p.s. Profile updated! Thumbs Up
Post #362121 Tue Nov 06 2012 3:18pm
Thumbs Up ON THE WAY: BMW F21 M140i
Post #362128 Tue Nov 06 2012 3:27pm
rangersport
Went for another drive. Mirror situation sorted. Thanks for that. Correct advice above in that when in reverse if adjusted will stay at these settings in reverse.
Still find sensors odd. For example when at lights if someone gets close behind te sensors at the back sound even though I am in drive. I'm sure will get used to it! Increases awareness I suppose.
Post #362173 Tue Nov 06 2012 8:38pm
mark hamster
senors come on automatically when you put it in reverse and stay on for 30 secs i think, then they switch off,but you can manually switch them off straight away by pressing the button on dash.! you can manually switch them on too by pressing same button.!
Post #362177 Tue Nov 06 2012 9:46pm
simple1
Sensors are fine, just get used to them. Once you go over 10 mph they switch off. I pull out of my office car park and hit a set of lights before doing more than 10 and everything sets them off.
The mirrors work well and will save your wheels but dip is p in a when reversing with trailer on the back so if you tow, get used to turning this function off when you hitch up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #362189 Tue Nov 06 2012 11:41pm
