![]() | Home > General > Heating not working. |
mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116 ![]() ![]() ![]() |
my guess is your fan has stopped working all together.! when you speed up its that, thats making you think your fan is working but i guess its not.! check fuses or relays for the heater |
farazk Member Since: 04 May 2012 Location: London Posts: 41 ![]() ![]() ![]() |
Do you know where I'll find the fuse box? Assuming fuses are fine will it be a big expensive repair?
AndyKay Member Since: 14 Jan 2012 Location: Leeds Posts: 226 ![]() ![]() ![]() |
it's behind the lower glove compartment RRS HSE TDV6 Autobiography |
Checked the fuse, seems to be fine, what else could it be? 2018 SVR |
Is it the blender. I know other members have reported issues with them failing. Not sure if that matches your symptoms though |
What is the blender? Where can I find it to check it?
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
I changes my blender motor 2 weeks ago.
Thanks guys, I'm getting cold air from all vents including rear and heated air only when I'm traveling over 50mph. Is there more than one blender or will I just need to replace the one? 2018 SVR |
Think its one left and one right. One under the glowbox and one near pedals.
