Home > General > Heating not working.
farazk
England 2005 Range Rover Sport TDV6 HSE Java Black
My heating or air con doesn't seem to work when I'm traveling at low speeds (below 50mph) but when I start traveling a bit faster its begins to work and the fans start blowing stronger aswell. What could be the problem? 2018 SVR
Post #359678 Mon Oct 15 2012 9:24am
mark hamster
my guess is your fan has stopped working all together.! when you speed up its that, thats making you think your fan is working but i guess its not.! check fuses or relays for the heater Rolling Eyes
Post #359745 Mon Oct 15 2012 1:34pm
farazk
Do you know where I'll find the fuse box? Assuming fuses are fine will it be a big expensive repair?
Thanks 2018 SVR
Post #359746 Mon Oct 15 2012 2:01pm
AndyKay
it's behind the lower glove compartment RRS HSE TDV6 Autobiography
Post #359758 Mon Oct 15 2012 2:48pm
farazk
Checked the fuse, seems to be fine, what else could it be? 2018 SVR
Post #360968 Fri Oct 26 2012 11:20am
Is it the blender. I know other members have reported issues with them failing. Not sure if that matches your symptoms though Confused ON THE WAY: BMW F21 M140i
Post #360969 Fri Oct 26 2012 11:25am
farazk
What is the blender? Where can I find it to check it?
Thanks 2018 SVR
Post #360975 Fri Oct 26 2012 11:53am
Shocked errmmm.... technical is not my forte Laughing
I believe they are under the dashboard, possible near the steering wheel on the drivers side and behind the glove box on the passenger side.
Couple of threads here:
http://www.rrsport.co.uk/forum/topic27848.html?highlight=blender
http://www.rrsport.co.uk/forum/topic25825.html?highlight=blender
Also stick +blender in the search box Thumbs Up ON THE WAY: BMW F21 M140i
Post #360976 Fri Oct 26 2012 12:10pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
I changes my blender motor 2 weeks ago.
Got cold air on right side and warm on left.
Its a straight forward job
My 56plate is left hand drive and the motor was located on the side of pedals RRS 2006 2.7 HSE
Post #360985 Fri Oct 26 2012 2:29pm
farazk
Thanks guys, I'm getting cold air from all vents including rear and heated air only when I'm traveling over 50mph. Is there more than one blender or will I just need to replace the one? 2018 SVR
Post #360987 Fri Oct 26 2012 2:44pm
RRSNorway
Think its one left and one right. One under the glowbox and one near pedals.
My left one fixed the problem with cold air at back and on front left side. RRS 2006 2.7 HSE
Post #360988 Fri Oct 26 2012 2:59pm
