![]() | Home > Technical > left blender motor replace |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
Yep! It's on my LHD side. How long did you spend on the removing/installing bit? My dealer shoud be able to do the job in around 2 hours? RRS 2006 2.7 HSE |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
I've not gone as far as you'll need to, but I reckon the console can be stripped bare in less than one hour. It seems scary at first because you sometimes have to pull quite hard to get the clips to release, and you spend more time fishing for them when they've fallen out than anything else. I am not sure about the side panel, but I have a feeling it either pulls up, or back towards the rear of the car to release, don't be tempted to pull it sideways (left-right) or you'll break the tabs that hold it onto the center console from what I could see when my console was apart.
Thanks for info!
Had a go with the center consoll today.
Do you mean the long one that slopes down towards the footwell and comes up along the radio more or less ? If so, you have to pull it towards the back of the car, pretty much horizontally. There are three clips iirc, but it takes quite a lot of force to pull it, and not many places to put your fingers behind it. ![]() "Roads ? Where we're going there are no roads." Back to the future. |
yes!
I presume you're talking about the curved and sloping bit pointed to by the red arrow in the picture below (slightly above the arrow point) ?
Perfect!!
That's the easy bit from what I can see ![]() ![]() "Roads ? Where we're going there are no roads." Back to the future. |
You know if I need to remove the fridge do get the sidepanel loose?
From memory: Two torx screws to remove the lid on top of the fridge, remove the grey covers, check for screws on front of fridge, but I don't think there are any, then yank fridge upwards, it's held in place by four clips underneath it. Before you yank it up, disconnect the wiring to it. Not sure what next steps are for getting the panels off. ![]() "Roads ? Where we're going there are no roads." Back to the future. |
Then again you might have to dig deeper !
Going to buy the blend motor part tomorrow.
No idea on left/right and good luck |
