Home > Technical > left blender motor replace
Page 2 of 3 <123>
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
RRSNorway wrote:
Damn!
Purhaps this is why my dealer said 6 hours Rolling Eyes
So the blender is located at my left leg, but I need to remove all the bits on my right leg side...
So this is the only way to get to the left blender on a LHD.
I might be getting confused with which side needs doing, but as far as I know, once you have removed most of the centre console, you can remove either side trim individually.
I guess being LHD, you're talking about removing what is your driver's side blend motor, so no worries about my comment earlier about the glove box removal.
"Roads ? Where we're going there are no roads." Back to the future.
Post #356515 Fri Sep 14 2012 9:47am
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Yep! It's on my LHD side. How long did you spend on the removing/installing bit? My dealer shoud be able to do the job in around 2 hours? RRS 2006 2.7 HSE
Post #356519 Fri Sep 14 2012 9:55am
mrfrog
I've not gone as far as you'll need to, but I reckon the console can be stripped bare in less than one hour. It seems scary at first because you sometimes have to pull quite hard to get the clips to release, and you spend more time fishing for them when they've fallen out than anything else. I am not sure about the side panel, but I have a feeling it either pulls up, or back towards the rear of the car to release, don't be tempted to pull it sideways (left-right) or you'll break the tabs that hold it onto the center console from what I could see when my console was apart.
I'd get a few spare clips if I were you.
Post #356524 Fri Sep 14 2012 10:04am
RRSNorway
Thanks for info!
I'v sent an email to my dealer asking what they will be doing for 6 hours on the car Smile RRS 2006 2.7 HSE
Post #356533 Fri Sep 14 2012 10:48am
RRSNorway
Had a go with the center consoll today.
Took my 10 min to remove the consoll, left airvent, plastic under the steering wheel.
Didn't find out how to remove the large plastic cover that goes from front to back. Its prob behind there the left blend motor is hiding:) Am I right? Anuone knows how to remove this? Its like 2 covers sitting on top of eachother. One that goes down from the vents and sitting ontop of the large side cover.
So If my dealer is using 6 hours to do this is a big joke! RRS 2006 2.7 HSE
Post #356727 Sun Sep 16 2012 3:51pm
mrfrog
Do you mean the long one that slopes down towards the footwell and comes up along the radio more or less ? If so, you have to pull it towards the back of the car, pretty much horizontally. There are three clips iirc, but it takes quite a lot of force to pull it, and not many places to put your fingers behind it.
Post #356731 Sun Sep 16 2012 5:36pm
RRSNorway
yes!
I tried to pull but was not sure it was the right way:)
But with a hard pull I can release the large panel to access the blend motor? RRS 2006 2.7 HSE
Post #356757 Sun Sep 16 2012 9:11pm
mrfrog
I presume you're talking about the curved and sloping bit pointed to by the red arrow in the picture below (slightly above the arrow point) ?
If so, it comes out in the direction of the green arrows.
Now the big panel (behind the orange arrows) either pulls up or back towards the rear of the car, but definitely not towards the driver/passenger door, you'll break clips.
If you have the console removed, look behind the panel, you should spot the clips and see which way they go.
Post #356769 Mon Sep 17 2012 7:55am
RRSNorway
Perfect!!
I'm going to try this again today Smile
Hope it's an easy swap from old to new motor. RRS 2006 2.7 HSE
Post #356772 Mon Sep 17 2012 8:52am
mrfrog
That's the easy bit from what I can see Laughing
Post #356784 Mon Sep 17 2012 9:36am
RRSNorway
You know if I need to remove the fridge do get the sidepanel loose?
If so could you give me a short guide on how to do this? Smile RRS 2006 2.7 HSE
Post #356790 Mon Sep 17 2012 11:16am
mrfrog
From memory: Two torx screws to remove the lid on top of the fridge, remove the grey covers, check for screws on front of fridge, but I don't think there are any, then yank fridge upwards, it's held in place by four clips underneath it.
Before you yank it up, disconnect the wiring to it.
Not sure what next steps are for getting the panels off.
Post #356791 Mon Sep 17 2012 11:25am
mrfrog
Then again you might have to dig deeper !
(Readable images in my gallery: http://www.rrsport.co.uk/gallery/index.php?cat=16521, go to "tech help")
Fridge:
Floor console:
Post #356793 Mon Sep 17 2012 11:39am
RRSNorway
Going to buy the blend motor part tomorrow.
After some research I think this is what needs to be done:
time: around 3 hours.
1. Remove centerconsoll and gearnob.
2. Remove chubby box(fridge)
3. Remove left airvent.
4. Remove panel under dashboard, side panel ut to airvent and the large panel from footwell to fridge
Some dudes in the US forum said that my LHD sport had the left blendmotor on the glovebox side.......sounds strange but could it be that the left motor is not on the steeringwheel side? RRS 2006 2.7 HSE
Post #357067 Tue Sep 18 2012 7:11pm
mrfrog
No idea on left/right and good luck Mr. Green
Post #357123 Wed Sep 19 2012 3:22pm
Page 2 of 3 <123>
