Home > In Car Electronics > tailgate glass release not working
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi, My tailgate glass ( top half of tailgate) will not open. Big Cry The whole tailgate opens fine. Is this on a fuse? Any ideas? itisme
Post #353469 Sun Aug 12 2012 8:17am
rogerpop
2008 Range Rover Sport TDV8 HSE Santorini Black
I had same problem last year, It turned out to be a corroded switch behind piece of rubber you press to release top half of tailgate. I cleaned it up and has been ok since (6 months)
Post #353490 Sun Aug 12 2012 3:34pm
Pufftmw
Had this issue when I bought mine. I had to take out the switch & replace it - 5 min job if that. The old one was completely junk and white powdery.
You then have to remember to unlock the car before it works Rolling Eyes Embarassed
Post #353525 Sun Aug 12 2012 7:52pm
Sag
I'm going to regret saying this;
The RRS has a split tailgate??????? All models??? (Mine is a 2006 55 HSE)
Must head out and do some investigation Embarassed LCFC. Receiver of threatening letters from Overfinch.
Post #353603 Mon Aug 13 2012 1:33pm
Rolling with laughter Sag........I know it was off the road for a while, but how long have you had the car Question Whistle Rolling with laughter
Technically not all models have a split tailgate, MY12 cars onwards have an electrically operated one piece Thumbs Up ON THE WAY: BMW F21 M140i
Post #353605 Mon Aug 13 2012 1:39pm
Pufftmw
Well, it does but only if the switch is working Wink
PMSL!
Post #353607 Mon Aug 13 2012 1:40pm
Sag
Embarassed Embarassed 4 and a half months!
Whenever I open the tailgate, I just press the round release button at the side and lift it up. How does the split work?? LCFC. Receiver of threatening letters from Overfinch.
Post #353609 Mon Aug 13 2012 1:41pm
harrygh60
Hi, rogerpop. Thanks, Problem solved. Used smalll screwdriver to scrape corrosion off, then gave a good dose of WD40. Thumbs Up Although i took the complete unit out. removing the number plate cover panel.8 Star screws.This gives access to back of number plate lights and problem switch.The problem was the mechanical part of the switch, It is a hinged piece of metal, when pressed through the rubber, operates a micro switch. The hinge corrodes and get stuck, so does not operate the micro switch. Pufftmw yours could probably been saved. How much was a new one itisme
Post #353612 Mon Aug 13 2012 1:46pm
Now, not having the split I'm not 100%, but grab your owners manual and all will be revealed.
Glass and wiper lift up separately or the whole thing.
Believe you can set the remote to unlock either Thumbs Up ON THE WAY: BMW F21 M140i
Post #353614 Mon Aug 13 2012 1:47pm
harrygh60
Hi,Sag. With the car unlocked. Press the rubber in middle of the number plate lights. An top half will click then lift up.Bottom right hand button releases the whole tailgate itisme
Post #353615 Mon Aug 13 2012 1:53pm
Sag
Ahhh ok, I have been pressing the button to release the whole thing.
Will give it a shot when I leave the office Thumbs Up LCFC. Receiver of threatening letters from Overfinch.
Post #353617 Mon Aug 13 2012 1:58pm
Pufftmw
About £35. I opened it up and it was all in pieces!
Post #353618 Mon Aug 13 2012 2:10pm
Sag
Ok so my upper tailgate does not release at all. No response from the switch when pressed. I assume it needs replacing so a quick forum & eBay search has shown me these:
Forum
http://www.land-rover-parts-shop.com/en/ui...;year=2005
eBay
http://www.ebay.co.uk/sch/i.html?_nkw=rang...;_osacat=0
The part numbers on the eBay ads dont match the ones in the link at the top?
Can anyone advise which I need for my 55 HSE?
Thanks, Sag Smile LCFC. Receiver of threatening letters from Overfinch.
Post #354165 Sun Aug 19 2012 5:55pm
scrumps
Sag,
FQR500170 (the top one) is the actual latch which hold the glass closed.
YUZ500020 ( one of the bottom ones) is the rubber covered switch above the rear number plate which operates the latch (the top one).
I hope that makes it a little clearer.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #354171 Sun Aug 19 2012 7:50pm
Sag
Thanks for clearing that up Scrumps. I think I should try the switch first in that case? LCFC. Receiver of threatening letters from Overfinch.
Post #354181 Sun Aug 19 2012 11:02pm
