Home > In Car Electronics > tailgate glass release not working |
rogerpop Member Since: 14 Jul 2012 Location: blackpool, Lancashire Posts: 14 |
I had same problem last year, It turned out to be a corroded switch behind piece of rubber you press to release top half of tailgate. I cleaned it up and has been ok since (6 months) |
Sun Aug 12 2012 3:34pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 |
Had this issue when I bought mine. I had to take out the switch & replace it - 5 min job if that. The old one was completely junk and white powdery.
Sun Aug 12 2012 7:52pm |
Sag Member Since: 07 Jul 2009 Location: Leicester Posts: 564 |
I'm going to regret saying this;
Mon Aug 13 2012 1:33pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Sag........I know it was off the road for a while, but how long have you had the car
Mon Aug 13 2012 1:39pm |
Well, it does but only if the switch is working PMSL! |
Mon Aug 13 2012 1:40pm |
4 and a half months!
Mon Aug 13 2012 1:41pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Hi, rogerpop. Thanks, Problem solved. Used smalll screwdriver to scrape corrosion off, then gave a good dose of WD40. Although i took the complete unit out. removing the number plate cover panel.8 Star screws.This gives access to back of number plate lights and problem switch.The problem was the mechanical part of the switch, It is a hinged piece of metal, when pressed through the rubber, operates a micro switch. The hinge corrodes and get stuck, so does not operate the micro switch. Pufftmw yours could probably been saved. How much was a new one itisme |
Mon Aug 13 2012 1:46pm |
Now, not having the split I'm not 100%, but grab your owners manual and all will be revealed.
Mon Aug 13 2012 1:47pm |
Hi,Sag. With the car unlocked. Press the rubber in middle of the number plate lights. An top half will click then lift up.Bottom right hand button releases the whole tailgate itisme |
Mon Aug 13 2012 1:53pm |
Ahhh ok, I have been pressing the button to release the whole thing.
Mon Aug 13 2012 1:58pm |
About £35. I opened it up and it was all in pieces! |
Mon Aug 13 2012 2:10pm |
Ok so my upper tailgate does not release at all. No response from the switch when pressed. I assume it needs replacing so a quick forum & eBay search has shown me these:
Sun Aug 19 2012 5:55pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 537 |
Sag,
Sun Aug 19 2012 7:50pm |
Thanks for clearing that up Scrumps. I think I should try the switch first in that case? LCFC. Receiver of threatening letters from Overfinch. |
Sun Aug 19 2012 11:02pm |
