![]() | Home > In Car Electronics > tailgate glass release not working |
rogerpop Member Since: 14 Jul 2012 Location: blackpool, Lancashire Posts: 14 ![]() ![]() |
I had same problem last year, It turned out to be a corroded switch behind piece of rubber you press to release top half of tailgate. I cleaned it up and has been ok since (6 months) |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Had this issue when I bought mine. I had to take out the switch & replace it - 5 min job if that. The old one was completely junk and white powdery.
Sag Member Since: 08 Jul 2009 Location: Leicester Posts: 564 ![]() ![]() ![]() |
I'm going to regret saying this;
Well, it does but only if the switch is working ![]() PMSL! |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Hi, rogerpop. Thanks, Problem solved. Used smalll screwdriver to scrape corrosion off, then gave a good dose of WD40. ![]() |
Now, not having the split I'm not 100%, but grab your owners manual and all will be revealed.
Hi,Sag. With the car unlocked. Press the rubber in middle of the number plate lights. An top half will click then lift up.Bottom right hand button releases the whole tailgate itisme |
Ahhh ok, I have been pressing the button to release the whole thing.
About £35. I opened it up and it was all in pieces! |
Ok so my upper tailgate does not release at all. No response from the switch when pressed. I assume it needs replacing so a quick forum & eBay search has shown me these:
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 554 ![]() ![]() |
Sag,
Thanks for clearing that up Scrumps. I think I should try the switch first in that case? LCFC. Receiver of threatening letters from Overfinch. |
