Home > General > Bloody thiefs
pc_rad
Scotland
Bloody thiefs
Some thieving gypsy has stolen the centre caps from my alloys grrr Twisted Evil grr I was only parked up for about thirty minutes. Anyway I now have to order some more. Are the centre caps off ebay all the same size, are they a standard fit.
Post #352760 Fri Aug 03 2012 11:48am
They do differ, so best to check the size you need.
Endjin seems to be suffering from a similar problem like you too, clearly a good market for secondhand centre caps in Scotland Sad ON THE WAY: BMW F21 M140i
Post #352762 Fri Aug 03 2012 11:52am
mse
Im impressed they got them off without damage - ive only every been able to do it behind the wheel.
There are also 2 types - the Rand Rover ones and the black Land Rover ones from earlier models. Mike
2014 Facelift Discovery
Post #352767 Fri Aug 03 2012 12:42pm
pc_rad
Scotland
There is a slight mark on the alloy.
They only got away with one. Parked in a decent area in Edinburgh.
I saw a set of replacement ones on eBay. They are black with range rover written on them, think they off the newer model.
My car has 20" stormers I think.
Post #352773 Fri Aug 03 2012 1:10pm
Endjin
Scotland
Sorry to see you have the same problem as me Rolling Eyes
I've lost 3 so far. I know what you mean about the mark on the wheel, the caps fit so tight that they need to use
something to lever them off. The marks on my wheels suggest a very small flat head screwdriver.
If you're caps are the ones with Land Rover wording on the Black Background then the part number is RRJ500030WYS
If they are Land Rover with green background then it's LR001156
If they are the new style with Range Rover and Black Background then it's LR027409
All of these part numbers are for a single cap (not a set).
You can buy them from your dealers parts dept or I tend to use LRDIRECT.COM
Here's a link to the LR Accessories page showing pics. (The standard ones on the wheels are the Sparkle Finish)
http://accessories.landrover.com/inter/mai...rMode=null
Hope this helps Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #352783 Fri Aug 03 2012 3:29pm
pc_rad
Scotland
Thanks for that. I measured them and the hole is about 43mm in diameter, its the one that is silver with the green land rover symbol. Would the new black caps with range rover fit. Fancy blinging my wheels Smile.
Thanks
Post #352799 Fri Aug 03 2012 5:27pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
If your wheels are genuine LR stormers (20"), then yes they do fit. It is the newer style that say range rover on them that look as if they are a different fitment
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #352812 Fri Aug 03 2012 9:52pm
codfather
Sorry, just re-read your post Embarassed , it is the "new" black land rover symbol one that fits! MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Post #352813 Fri Aug 03 2012 9:53pm
pc_rad
Scotland
Hmm......
I'm confused now. Is it possible for a direct swap between silver with green land rover logo to black with silver range rover on them.
Dam thiefs, grrrrrr
Post #352819 Fri Aug 03 2012 10:33pm
mse
Probably yes
You can definitely swop the stand land rover badge with the - black land rover badge centre fitted on range rovers pre 12.
One question to ask - do you want to take all your wheels off?
If you have only lost one, the only sure way to replace the lot is remove the wheel and knock the centre cap out...thus allowing a matching set of 4
If you replaced the one you lost you can pop it in without removing the wheel Mike
Post #352820 Fri Aug 03 2012 10:43pm
pc_rad
Scotland
Taking the wheels off is not an issue.
I plan on painting the hubs and silver and black as they are looking a bit tired for only being on the car three years.
Shocking quality to be honest on the hubs.
Might treat them too some nice shiny Brembo stickers.
Hope it doesn't look too chavy
Post #352822 Fri Aug 03 2012 10:54pm
mse
I have all the pro gear and regularly switch a full set of tyres from road to off road muds on the other land rovers - its a complete ball ache, especially only to do for the centre caps - but if there are other reasons then go for it. Mike
Post #352838 Sat Aug 04 2012 10:13am
