![]() | Home > General > Bloody thiefs |
They do differ, so best to check the size you need.
Im impressed they got them off without damage - ive only every been able to do it behind the wheel.
pc_rad Member Since: 16 Mar 2012 Location: Dundee Posts: 6 ![]() ![]() |
There is a slight mark on the alloy.
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
Sorry to see you have the same problem as me |
Thanks for that. I measured them and the hole is about 43mm in diameter, its the one that is silver with the green land rover symbol. Would the new black caps with range rover fit. Fancy blinging my wheels |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
If your wheels are genuine LR stormers (20"), then yes they do fit. It is the newer style that say range rover on them that look as if they are a different fitment
Sorry, just re-read your post |
Hmm......
Probably yes
Taking the wheels off is not an issue.
I have all the pro gear and regularly switch a full set of tyres from road to off road muds on the other land rovers - its a complete ball ache, especially only to do for the centre caps - but if there are other reasons then go for it. Mike
