Home > General > Bloody thiefs |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
They do differ, so best to check the size you need.
Fri Aug 03 2012 11:52am |
Im impressed they got them off without damage - ive only every been able to do it behind the wheel.
Fri Aug 03 2012 12:42pm |
pc_rad Member Since: 16 Mar 2012 Location: Dundee Posts: 6 |
There is a slight mark on the alloy.
Fri Aug 03 2012 1:10pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Sorry to see you have the same problem as me
Fri Aug 03 2012 3:29pm |
Thanks for that. I measured them and the hole is about 43mm in diameter, its the one that is silver with the green land rover symbol. Would the new black caps with range rover fit. Fancy blinging my wheels .
Fri Aug 03 2012 5:27pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
If your wheels are genuine LR stormers (20"), then yes they do fit. It is the newer style that say range rover on them that look as if they are a different fitment
Fri Aug 03 2012 9:52pm |
Sorry, just re-read your post , it is the "new" black land rover symbol one that fits! MY10 TDV6 SE (debadged ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Fri Aug 03 2012 9:53pm |
Hmm......
Fri Aug 03 2012 10:33pm |
Probably yes
Fri Aug 03 2012 10:43pm |
Taking the wheels off is not an issue.
Fri Aug 03 2012 10:54pm |
I have all the pro gear and regularly switch a full set of tyres from road to off road muds on the other land rovers - its a complete ball ache, especially only to do for the centre caps - but if there are other reasons then go for it. Mike
Sat Aug 04 2012 10:13am |
