Home > Faults & Fixes > Blanking EGR valves on 08 sport
Page 4 of 6 <123456>
bellautos
United Kingdom 2005 Range Rover Sport TDV6 HSE Cairns Blue
Snowski, Glad you got the kit fitted ok. MPG is not normally worse from blanking the EGR's and some report a gain, However if the garage has done a hard driving road test before handing you the car back it could show low for the next few miles untill it settles with your normal driving again.
pete
Post #337628 Fri Mar 23 2012 8:31pm
SRE
Spain
Pete.
Any chance of an update / status on a software patch to close the EGR Valves ?
Syd In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #337652 Sat Mar 24 2012 9:38am
Snowski
Netherlands 2005 Range Rover Sport TDV6 HSE Cairns Blue
pete
I've reset the counters and will also measure gas mileage from full tank to full tank. I've read reports that fuel economy can actually improve.
Thanks again for great service.
Post #337708 Sat Mar 24 2012 9:34pm
avos
@D4jww,
Have checked the P0402 code in more detail, and it is a relevant code actually. Besides the MAP, the ECU is also using the MAF to check the operation of the EGR. So, when you blank of the EGR, there will be more airflow under the check conditions. Did the code ever came back? RRS SDV6 HEV Dynamic
XKR 700 BHP with Twin-screw and LSD
Post #337929 Tue Mar 27 2012 3:54am
D4jww
Yes and it's a big frustration p0402 appear and then 4 other codes( all relating to loosing coms with engine ecu)that gives 4 warning lights and then suspension lowering as explained in my post http://www.disco3.co.uk/forum/topic77360.html
I am realy going crazy, because it's intermittent did a 60 mile run yesterday and none of the codes showed. However the latest sequence is start engin after running FBH so half normal coolant temp then town driving for half a mile, results in 4 warning lights + suspp lowering, ignition of check and clear codes restart drive 39 miles highway with longer that 4.6seconds down hills, no problem not even a none tested fault nothing. Help with explaining this sequence of events that result in the D3 thinking its a problem that requires lowering of suspp??????
I am close to the point of removing the blanking kit and return to normal but that would be terrible so plan B put butterfly back but drill holes in it??? Comment on the success of this would be helpful!!
Anothe option is some one mentioned that on a jaguar forum it has work on similiar engine because of the use of bleeding holes( more info would help) Banging Head Banging Head Banging Head
Post #338416 Sun Apr 01 2012 8:02am
SRE
Spain
I am pretty sure I read on a Jag forum that they uses a 7mm hole, however I think that is with one EGR valve, so if you are drilling holes in 2 EGR valve then i would assume you would need 2 hole with half the area of the 7 mm hole.
Pi R Squared when I went to school
This may help with your math
http://www.calculatorsoup.com/calculators/...circle.php Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #338419 Sun Apr 01 2012 9:18am
D4jww
Thanks SRE, can you remember if that's in the erg blanking plate or the Buttefly valve? Because I would want to avoid hole in the blanking plate, because the objective with this mod was to avoid exhaust gasses going back into the inlet manifold. Big Cry
Short trip today no motor way driving and My D3 is lowering again, DTC P0402 is back Big Cry
Post #338429 Sun Apr 01 2012 12:27pm
avos
Do you only get the code P0402, or also the check engine light? RRS SDV6 HEV Dynamic
Post #338430 Sun Apr 01 2012 12:39pm
D4jww
No engine management light, just p0402! Maybe my vin 9A499*** has got something to do with it, the spesial lowering suspension safety feature Evil or Very Mad Evil or Very Mad
Post #338432 Sun Apr 01 2012 12:51pm
avos
Just having the code isn't any issue, or is there? RRS SDV6 HEV Dynamic
Post #338433 Sun Apr 01 2012 12:57pm
D4jww
No got 5 other DTC all intermitted and basicly loosing comms with engine ECU see summary http://www.disco3.co.uk/gallery/displayima...amp;pos=27
Ride is a bit bouncy but looks good in London Embarassed
Avos Is there away you could read your Engine ECU software reference?
Post #338434 Sun Apr 01 2012 1:02pm
SRE
Spain
Now your asking, I think it was in the blanking plate, I will have to do a little googleing, see if I can find it again. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #338435 Sun Apr 01 2012 1:05pm
SRE
Spain
Photo on here of plate with hole in
Scroll down a tad
http://www.jaguarforum.co.uk/viewtopic.php...ntercooler In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #338436 Sun Apr 01 2012 1:16pm
D4jww
Thanks
@AVOS, No got 5 other DTC all intermitted and basicly loosing comms with engine ECU see summary http://www.disco3.co.uk/gallery/displayima...amp;pos=27
Avos Is there away you could read your ECU software reference?
Post #338438 Sun Apr 01 2012 1:29pm
avos
Ok, than you are fine with the EGR blanking, I think I also got the P0402 (will check again later), but no check engine light, and no change in behavior, so all is well.
Have no idea what could be wrong with the Suspension issue, here a summary of the codes:
ABS & Air suspension U0401 : Invalid Data Received from ECM/PCM A - Event information: Check ECU for errors
Terrain Response : U0416 : Invalid Data Received From Vehicle Dynamics Control Module, Check ABS for Errors
Instrument: U0132: Lost Communication With Suspension Control Module "A" - Missing message, Check Ride Level Control Module
Body Control : B1D17 : Lost communication with BBUS (Battery Backed Sounder)
I can check what ECU software I have, but I don't think it will help here. RRS SDV6 HEV Dynamic
Post #338439 Sun Apr 01 2012 1:45pm
