![]() | Home > Faults & Fixes > Blanking EGR valves on 08 sport |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
Mike - can you let us know if anything changes. Most people think about blanking when the EGRs have failed and with earlier Vins put on blanks when the EGRs have failed as a cost saving exercise. Maybe the clue to yours working is the fact you also replaced the EGRs as well so maybe blanks do work as long as the egrs also work - maybe their sensor is more critical than the sensor that detects whether gas comes through to the engine. Did you use blanks on the EGR or on the inlet port? Cheers Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 ![]() |
@Mike,
Mike waldie Member Since: 09 Nov 2011 Location: Cronton Posts: 147 ![]() ![]() ![]() |
Vin on mine is SALLSAA138A158xxxx Hope this helps |
Still all good with no codes |
So far also my car is running fine. We may establish a range of cars that can be blanked of, so at least 8A123xxx and 8A158xxx are so far fine.
How much are those kits and where did you get yours??? |
Am no expert on this so it is also a trail for me (with prime purpuse to cleanup inside), but choose the Stage 3 kit from cooling mist:
So far I have not noted any (pending) codes, am still puzzled as to why the P0401 is not popping up.
D4jww Member Since: 08 Feb 2012 Location: London Posts: 18 ![]() |
Being a my08D3 owner, I am watching this tread with great interest, please keep us updated! |
Being doing that bud, letting it roll etc and still the same!!!! Car running great so maybe sorted. Only probs I'm having is my front bushes I think, got knocking noise on small bumps. |
Might just be arb bushes have you had the sims fitted already or is that just D3's? |
Still running fine guys.. It defo can be done... |
Any chance you can post some more info, e.g what blanks did you use etc. I am interested as my VIN SALLSAA148A16#### Syd In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
So far also here everything is fine, am still puzzled actually as to why.
