![]() | Home > General > Higher or lower mileage car? |
Ahhh Yes apparently that's Vesuvius Red ![]() Audi SQ5...Gone Audi Q7 S-Line 240 3.0TDI Gone Audi A6 Allroad Sport 270 3.0TDI |
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Thanks Ady! Sounds like a bit of a "Friday afternoon" vehicle and, given I am going to Morocco in it this year (and who knows where next year!), I need a dependable car - don't want to be buying into trouble! |
The middle "red" you're not so keen on looks like Rimmi Red |
Thanks, one to avoid - only because the missus would get matching lipstick and claim it as hers within the first week!! |
bosun Member Since: 16 Dec 2011 Location: west wales Posts: 20 ![]() ![]() |
They're all a bit 'friday afternoon' in my humble opinion !
I think you had a bad experience by the sounds of it bosun, but hopefully not all cars are the same!
The problem with mine was that despite full service history and despite the fact that the timing belt isn't due until 105,000 miles,at 60k part of the front engine casing (that is an inanimate part that should last forever) Sheared off without warning causing the intact timing belt to slip off the sprockets and the valves to hit the pistons and trash the engine. And you can't even get the heads off without having a two post lift to lift the whole body off the rolling chassis. So no way to predict if its going to happen even if you replace the belt as a precaution.
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
Should have carried on with the argument, mine cost over 10,000 for the brand new engine, turbo and pump
^^^ And a good tip off |
