Home > General > Transmission Fault & HDC Unavailable
ajp166
Got this message on car today... it lowered the suspension etc... Switched car off and back on and error was still there did it again and error was gone... should I be worried or it's a common problem? it was quite cold so perhaps that didn't help? also I have a red airbag light on which maybe is affecting somehow...
Post #329337 Tue Jan 24 2012 4:13pm
Have you got a rear bulb out by anychance Question this can cause alsorts of funny behaviour with the electrics
Post #329340 Tue Jan 24 2012 4:20pm
ajp166
no rear bulb out mate.... it says transmission fault and park brake fault.... it came on agin this evening...
Post #329569 Thu Jan 26 2012 2:08am
richyrich70
Is your battery ok? I had a few faults come up, found that the battery was on its way out. Replaced it and (fingers crossed) no more error messages!
Post #329573 Thu Jan 26 2012 7:40am
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
has it been wet recently and/or power-washed - water ingress could cause this ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #329585 Thu Jan 26 2012 9:21am
ajp166
Went halfords guys.. battery was unservicable.... dead.
New 12v 100amp battery installed... red airbag light on but hopefully no more HDC issues..
Post #329831 Fri Jan 27 2012 7:22pm
Thanks for all your help and suggestions guys Neutral Arrow
Post #329838 Fri Jan 27 2012 9:09pm
ajp166
Yes thanks a lot guys... Very very appreciated! Wink))
Post #329856 Sat Jan 28 2012 1:10am
ajp166
Guys went land rover today and they reset the airbag and said this issue mentioned above is a 'Faulty brake switch'... it came up on the system... they will fix it tomorrow while I wait.... has anyone had this issue?
Post #330544 Wed Feb 01 2012 10:39pm
rrsboy
is it a Stratstones? that sounds very much like a Stratstones thing to say
Rolling with laughter ============
Post #330555 Wed Feb 01 2012 11:13pm
swe-felix
Sweden 2008 Range Rover Sport TDV8 HSE Santorini Black
I've had the exact same problem, for me its been going on for 4 months. First they changed parts of the wiring(had it in for 3 weeks) but that didn't help. After that i heard that it may be caused by having a bad battery, changed it to one from BMW witch they use in their large diesels and it was sopposed to be a lot stronger. All well for about 2 months until the water sensor broke in -20 deg. During the fix of the problem with the water sensor the battery run out. Recharged it at land rover but after about 2 h of drive it came up again. Now it comes on from time to time. Going back to LR tomorrow, hopefully they will find something. RRS TDV8 -08
Post #330564 Wed Feb 01 2012 11:51pm
ajp166
No it was Wimbledon Land Rover... they spent 40 mins today on the car, they fixed the airbag light and didn't even charge a penny ... they are very decent guys I think.... The fault came up regarding the switch as I have been getting faults on the dash.... I think £70 odd quid to fix the switch tomorrow while I wait..
Post #330566 Thu Feb 02 2012 12:26am
Mcfeat
United Kingdom 2005 Range Rover Sport TDV6 SE Zambezi Silver
I had the same problem changed the two stop light bulbs and been fine since Smile
Post #399271 Mon Oct 21 2013 12:15pm
