Home > General > Transmission Fault & HDC Unavailable |
Have you got a rear bulb out by anychance this can cause alsorts of funny behaviour with the electrics |
Tue Jan 24 2012 4:20pm |
ajp166 Member Since: 10 Jul 2011 Location: london, UK Posts: 241 |
no rear bulb out mate.... it says transmission fault and park brake fault.... it came on agin this evening... |
Thu Jan 26 2012 2:08am |
richyrich70 Member Since: 04 Nov 2011 Location: Cheltenham Posts: 28 |
Is your battery ok? I had a few faults come up, found that the battery was on its way out. Replaced it and (fingers crossed) no more error messages! |
Thu Jan 26 2012 7:40am |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
has it been wet recently and/or power-washed - water ingress could cause this ============
Thu Jan 26 2012 9:21am |
Went halfords guys.. battery was unservicable.... dead.
Fri Jan 27 2012 7:22pm |
Thanks for all your help and suggestions guys |
Fri Jan 27 2012 9:09pm |
Yes thanks a lot guys... Very very appreciated! )) |
Sat Jan 28 2012 1:10am |
Guys went land rover today and they reset the airbag and said this issue mentioned above is a 'Faulty brake switch'... it came up on the system... they will fix it tomorrow while I wait.... has anyone had this issue? |
Wed Feb 01 2012 10:39pm |
is it a Stratstones? that sounds very much like a Stratstones thing to say
Wed Feb 01 2012 11:13pm |
swe-felix Member Since: 01 Feb 2012 Location: stockholm Posts: 1 |
I've had the exact same problem, for me its been going on for 4 months. First they changed parts of the wiring(had it in for 3 weeks) but that didn't help. After that i heard that it may be caused by having a bad battery, changed it to one from BMW witch they use in their large diesels and it was sopposed to be a lot stronger. All well for about 2 months until the water sensor broke in -20 deg. During the fix of the problem with the water sensor the battery run out. Recharged it at land rover but after about 2 h of drive it came up again. Now it comes on from time to time. Going back to LR tomorrow, hopefully they will find something. RRS TDV8 -08 |
Wed Feb 01 2012 11:51pm |
No it was Wimbledon Land Rover... they spent 40 mins today on the car, they fixed the airbag light and didn't even charge a penny ... they are very decent guys I think.... The fault came up regarding the switch as I have been getting faults on the dash.... I think £70 odd quid to fix the switch tomorrow while I wait.. |
Thu Feb 02 2012 12:26am |
Mcfeat Member Since: 10 Dec 2012 Location: Scotland Posts: 5 |
I had the same problem changed the two stop light bulbs and been fine since |
Mon Oct 21 2013 12:15pm |
