![]() | Home > General > Transmission Fault & HDC Unavailable |
Have you got a rear bulb out by anychance |
ajp166 Member Since: 10 Jul 2011 Location: london, UK Posts: 241 ![]() ![]() |
no rear bulb out mate.... it says transmission fault and park brake fault.... it came on agin this evening... |
richyrich70 Member Since: 04 Nov 2011 Location: Cheltenham Posts: 28 ![]() ![]() |
Is your battery ok? I had a few faults come up, found that the battery was on its way out. Replaced it and (fingers crossed) no more error messages! |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
has it been wet recently and/or power-washed - water ingress could cause this ============
Went halfords guys.. battery was unservicable.... dead.
Thanks for all your help and suggestions guys |
Yes thanks a lot guys... Very very appreciated! ![]() |
Guys went land rover today and they reset the airbag and said this issue mentioned above is a 'Faulty brake switch'... it came up on the system... they will fix it tomorrow while I wait.... has anyone had this issue? |
is it a Stratstones? that sounds very much like a Stratstones thing to say
swe-felix Member Since: 02 Feb 2012 Location: stockholm Posts: 1 ![]() ![]() ![]() |
I've had the exact same problem, for me its been going on for 4 months. First they changed parts of the wiring(had it in for 3 weeks) but that didn't help. After that i heard that it may be caused by having a bad battery, changed it to one from BMW witch they use in their large diesels and it was sopposed to be a lot stronger. All well for about 2 months until the water sensor broke in -20 deg. During the fix of the problem with the water sensor the battery run out. Recharged it at land rover but after about 2 h of drive it came up again. Now it comes on from time to time. Going back to LR tomorrow, hopefully they will find something. RRS TDV8 -08 |
No it was Wimbledon Land Rover... they spent 40 mins today on the car, they fixed the airbag light and didn't even charge a penny ... they are very decent guys I think.... The fault came up regarding the switch as I have been getting faults on the dash.... I think �70 odd quid to fix the switch tomorrow while I wait.. |
Mcfeat Member Since: 10 Dec 2012 Location: Scotland Posts: 5 ![]() ![]() ![]() |
I had the same problem changed the two stop light bulbs and been fine since |
