![]() | Home > General > HELP please .. I've dropped a massive Bo**ock |
NickM Member Since: 15 Feb 2008 Location: London Posts: 2995 ![]() ![]() |
ok, I would wait until the morning and see if it resets itself - I think it will. If that fails, then look to disconnect the battery. But i think overnight should cure it.
olyb223 Member Since: 24 Nov 2011 Location: Dubai Posts: 29 ![]() ![]() |
Thanks Nick, I doubt I'll sleep much with $40k on the line that I'm supposed to collect first thing. What a tit, I wish I'd had just drove home and not bothered about having it 'shiney' for the new owner. I'm praying it'll be ok - what's the worst that could have happened? shorted relay? I feel sick.... |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
this exact thing happened to me on the 57 plater and I fixed it by getting it HOT - took it for a big run up the motorway at, let's say, speed for more than an hour. That fixed most of the faults but it did take a few days for all of them to clear. Given you're in Dubai where the ambient temperature is much higher I suspect you may have a quicker time of it. ============
Thanks pal. I've got till the morning to fix it. I'm so annoyed that I did it. It wasn't even dirty I just wanted it looking mint for the Girl that's bought it out of courtesy. olly |
wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99 ![]() ![]() |
You are best of starting with the module behind the battery . You need to remove the battery and then the module (which is fixed to the front of the main ECU )
Cheers Wiggs, is there anything else I should look out for with re-connecting the battery? I've just been reading that on older models you have to turn the steering wheel full lock either way on first start up to set the suspension up, remove a earth from the bulkhead for 20 mins, reset the radio etc.. This could get messy. I'll try it again in an hour or so when Leeds have whooped Arsenal and is its still the same I'll drive it for an hour or so, failing that I'll get handy with the spanners, I'd rather not as I tend to ![]() What a time for this to happen, I was debating weather to even clean it.. |
What year is your car ? Bluetooth Exchange www.bluetoothexchange.co.uk |
Technically 06 but it's registered as a 08 as it was shipped then sat here for 18 months before it was bought. |
Don't need to do any thing fancy when connecting the battery .... Just reset the clock |
great result on the football - it's not all bad!! |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
So,how is it this morming??? Range Rover Vogue ‘17 TDV6
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
No good deed goes un punished!!! lets hope that's not the case here.....Hope its worked itself out !! |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 ![]() ![]() ![]() |
please let us know how you got on. |
