Home > General > HELP please .. I've dropped a massive Bo**ock
Page 1 of 3 123>
olyb223
United Arab Emirates
So, I've sold my RRS sport S/C today and taken a deposit off the new owner.
As I'm dropping it to them in the morning, out of courtesy I took it for one last clean and went for the full body and engine bay clean. The muppet in the car wash has gone mad with his Jet hose and I've gone to drive off and have Error messages galore.
First one that comes up is "special programs off" Followed by "System Fault Special programs not Available" Basically every terrain setting is inactive.
Clearly there is water in the electrics. I can't take it to the new owner like this and the Car wash are defecting any responsibility for it. Its 11PM in Dubai and I'm dropping it with the new owner at 9AM in the morning.
I've driven it for about 20 miles to see if it dries out and nothing!
WTF am I gonna do? What would I need to remove and dry? Ive tried compressed Air but don't even know where to start. Would hard reset work?
I was just trying to send her off to the new owner sparkling and this has jepordised the whole thing!
Can anyone advise/help?
I was just about to disconnect and reconnect the battery or is that a bad idea?
Post #327470 Mon Jan 09 2012 7:54pm
NickM
ok, I would wait until the morning and see if it resets itself - I think it will. If that fails, then look to disconnect the battery. But i think overnight should cure it.
i remember once getting my car cleaned and the EGR valves happend to go as I drove off, and boy was I Censored off, but just one of those things.
Wait til the morning and see what happens. I think it will be ok
Good luck!
Post #327471 Mon Jan 09 2012 8:04pm
olyb223
and then
Post #327472 Mon Jan 09 2012 8:09pm
olyb223
Good luck!
Thanks Nick, I doubt I'll sleep much with $40k on the line that I'm supposed to collect first thing.
What a tit, I wish I'd had just drove home and not bothered about having it 'shiney' for the new owner.
I'm praying it'll be ok - what's the worst that could have happened? shorted relay?
I feel sick....
Post #327474 Mon Jan 09 2012 8:12pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
this exact thing happened to me on the 57 plater and I fixed it by getting it HOT - took it for a big run up the motorway at, let's say, speed for more than an hour. That fixed most of the faults but it did take a few days for all of them to clear. Given you're in Dubai where the ambient temperature is much higher I suspect you may have a quicker time of it. ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #327475 Mon Jan 09 2012 8:19pm
olyb223
Thanks pal. I've got till the morning to fix it. I'm so annoyed that I did it. It wasn't even dirty I just wanted it looking mint for the Girl that's bought it out of courtesy.
olly
Post #327476 Mon Jan 09 2012 8:24pm
wiggs
You are best of starting with the module behind the battery . You need to remove the battery and then the module (which is fixed to the front of the main ECU )
the outer ali cover needs to be taken off and you will find all the circuits to be damp . Spray with some electrical cleaner / wd40 and dry it out with a hair dryer
i have seen it a few times ...the water runs down the inside of the bonnet ( or directly sprayed down behind the battery ) and gets into the module Bluetooth Exchange www.bluetoothexchange.co.uk
Post #327483 Mon Jan 09 2012 8:48pm
olyb223
Cheers Wiggs, is there anything else I should look out for with re-connecting the battery? I've just been reading that on older models you have to turn the steering wheel full lock either way on first start up to set the suspension up, remove a earth from the bulkhead for 20 mins, reset the radio etc.. This could get messy. I'll try it again in an hour or so when Leeds have whooped Arsenal and is its still the same I'll drive it for an hour or so, failing that I'll get handy with the spanners, I'd rather not as I tend to Censored things up quite easily.
What a time for this to happen, I was debating weather to even clean it..
Post #327490 Mon Jan 09 2012 9:25pm
wiggs
What year is your car ? Bluetooth Exchange www.bluetoothexchange.co.uk
Post #327492 Mon Jan 09 2012 9:32pm
olyb223
Technically 06 but it's registered as a 08 as it was shipped then sat here for 18 months before it was bought.
Post #327496 Mon Jan 09 2012 9:39pm
wiggs
Don't need to do any thing fancy when connecting the battery .... Just reset the clock Thumbs Up Bluetooth Exchange www.bluetoothexchange.co.uk
Post #327500 Mon Jan 09 2012 9:54pm
rrsboy
great result on the football - it's not all bad!! Whistle ============
Post #327512 Mon Jan 09 2012 10:54pm
Jimmy_75000
So,how is it this morming??? Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #327531 Tue Jan 10 2012 8:36am
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
No good deed goes un punished!!! lets hope that's not the case here.....Hope its worked itself out !!
Post #327539 Tue Jan 10 2012 10:27am
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
please let us know how you got on.
Post #327561 Tue Jan 10 2012 11:53am
Page 1 of 3 123>
