Home > Technical > Amazing decrease in fuel consumption!
another consideration is the winter/autumn ambient temps....ie no air con every trip and better air temp for combustion Thumbs Up RRS gone
Post #320811 Fri Nov 11 2011 2:51pm
Jmac
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
both good points.. Thumbs Up I'll see what distance i'm able to cover with this tank and report back.. I always use my air-con - otherwise the car steams up if it's damp...
it is very puzzling though..
J
Post #320813 Fri Nov 11 2011 3:26pm
certainly would be interesting to see Thumbs Up RRS gone
Post #320819 Fri Nov 11 2011 3:52pm
JonnyDangerous
OK - I've done the exact same change as the OP. Changed from 20" conti"s to 19" wintrac extremes and got the exact same result. My MPG display has changed from averaging 26mpg to now being 32mpg. I've only changed the wheels over this weekend so will report back in a couple of weeks.
the ride is definitely better on 19's too.
Post #321793 Sat Nov 19 2011 5:37pm
mse
Ive noted that the fuel heater can knock around 2mpg off depending on use Mike
2014 Facelift Discovery
Post #321882 Sun Nov 20 2011 6:19pm
