![]() | Home > Technical > Amazing decrease in fuel consumption! |
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 ![]() ![]() ![]() |
I think you mess up your MPG computer when you change wheel sizes? |
Jmac Member Since: 17 Feb 2011 Location: South Posts: 125 ![]() ![]() ![]() |
I totally agree that new tyres will give different readings when compared to worn out ones due to a different rolling radius but 20% ![]() Also, as the tyres are LR specification sizes for the car, I would have thought the car should be pretty accurate for both sizes.. cheers, J |
JonnyDangerous Member Since: 09 Nov 2009 Location: Reading Posts: 57 ![]() ![]() ![]() |
hmmm - i always thoughts (maybe incorrectly) that the actual circumference of the wheel is the same if its a 19" or 20" rim as the inch difference on the 19" rim is made up by a tyre that is less low profile.
I thought the same and although there may be a difference it shouldn't throw out the numbers that much surely! will be interested to hear if your numbers change too.. I'm using the vredestein wintracks (sp?) Cheers, J |
we can compare notes as that's the tyre i'm putting on too. Just need to wait for it to get a bit colder. |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
There is a tyre change button on my satnav, which resets it to new tyres thought is is the fl2 |
Hmmm. I do remember something about that. I will investigate in the morning. Cheers, j |
iirc 20" rims read slightly quick on the speedo.
Interesting, mines got 20's as standard, so I would assume they have resolved this |
Sorry I should have clarified...
My car had the 20s as std so that might be an explanation but the difference does seem massive.. |
so are we talking 20mpg to 24?
I don't look at the MPG reading as I know it's optimistic - I just add the two numbers from the range to go and distance travelled since I filled up. All I can say is that it used to add up to 400 miles and now it adds up to 490. If we assume the tank holds 84 (18.5 gallons) litres then that means a jump from 21.6mpg to 26.5mpg.. Seems like an awful lot to me for a very small change in diameter... |
I'd not take too much notice of range either |
